August 22, 2025, 08:06:36 AM *
Author Topic: Starter Motor  (Read 6472 times)
Not Happy Jan
Aussie adventure
« on: April 14, 2012, 09:12:16 PM »
Had been driving all day and got home for a bite to eat... tried to restart and just went click.... Lights go  on and It will clutch start no probs... thats starter motor right. Huh Huh
 Tried tapping it a couple of times to no avail. Ie there somethomg else I could to rather than replace the whole unit???
Nick
You can never have too many!
Port Macquarie NSW
Maco
« Reply #1 on: April 14, 2012, 09:33:00 PM »
Nick,
How old is your battery?
Better in Green
Stewy
sa-club
Jeff Stewart
« Reply #2 on: April 14, 2012, 11:09:54 PM »
I'm with you John, Nick check the battery first.
After having no warning signs one morning, drove 50 kms to work, stopped turned car off got out,
got straight back in to move further forward and that dreaded click sound.
Put in a mates battery started first time and drove to nearest battery dealer to buy new one. all good
Batteries can be naughty things  Tongue
Cheers Stewy   Cool
« Reply #3 on: April 14, 2012, 11:15:09 PM »
I agree.
Check the battery posts and leads to ensure all is tight and clean and you are getting a good contact.
Not Happy Jan
Aussie adventure
« Reply #4 on: April 15, 2012, 10:45:51 AM »
Thanks Boys..... will check it out in a minute....just been on a 60K cycle this am and I'm buggered Tongue
Don't know how old the battery is but it does not surprise me that that could be the problem, I have a spare so I'll swap them over and let you know!
Nick
Port Macquarie NSW
Not Happy Jan
Aussie adventure
« Reply #5 on: April 15, 2012, 12:03:24 PM »
I just went down and it did crank over after sitting for the night.... SO GOOD CALL EVERYONE!!!!! Grin Grin Grin Wink
Changed the battery from a couple of spares I had and put the other on charge?? AS I said I couldn't tell you the age of it so I don't know how successful the recharge will be? Cleaned all the terminals and she is running again. Time for a oil change and a grease up!
Thanks to all again!
Nick
Port Macquarie NSW
Not Happy Jan
Aussie adventure
« Reply #6 on: April 15, 2012, 02:06:44 PM »
Battery was fully charged so I took it for a spin before changing the oil. Back up into the driveway and then the same thing..Just clicked.I'm going to check all the connections again and give them a clean
Port Macquarie NSW
« Reply #7 on: April 15, 2012, 03:56:26 PM »
Check power wire to starter and earth to block.
also if your terminals are the stick the wire in and do the screw up type clean them out or try a jumper lead direct from the positive to the starter...
Have fun old cars can be a pain in the backside sometime..
Stewy
sa-club
Jeff Stewart
« Reply #8 on: April 15, 2012, 07:45:10 PM »
Hi Nick,
Dont trust an old battery, even if its been on the charger and seems fully charged.
Only way to check is when your cranking it over with a meter to see what the cranking voltage is.
Father in laws 2009 lancer died in our driveway the other week, I put my meter on static it read 13.8 volts
rang RAA, when they turned up the cranking voltage was only 10.2 volts, answer change battery all good
I asked about keeping old one and recharging, patrol said these days would not bother.
Personally I would buy a new one and know what youve got before needing to chase the next point of failure
I'm with you Pete, you have to love these old cars.  Smiley
Cheers Stewy   Cool
Not Happy Jan
Aussie adventure
« Reply #9 on: April 22, 2012, 05:13:18 PM »
The saga Continues. Sad Sad Sad Angry
The problem with the starting became very intermittent.... Just the ones you love...the battery had a good charge and would crank over the other FC no problems.
Anyway... I would start it ok then go for a drive get home and then it would just click. Come back the next morning and it would turn over again.... Today this morning I just kicked it over for a couple of cranks and then stopped.... 10 seconds later CLICK..So today I changed the leads to the soleniod and also the earth lead... Still the same  just a click... so I bit the bullet and went and bought a new battery.. 148 bucks. got it back a minute ago and installed it and CLICK. Not a good week to give up alcohol. Tongue
It does have a relay attached to the solenoid and that goes to the regulator and the generator... What would the function of that be???
Any ideas.. I think that it may be the solenoid. Is that an easy fix??? Something I could do or should I get it overhauled. I have never been anygood with electrics Undecided
Thanks for the help!
Port Macquarie NSW
Not Happy Jan
Aussie adventure
« Reply #10 on: April 22, 2012, 05:26:16 PM »
Anyone wanna buy a battery Grin Grin Grin
Port Macquarie NSW
KFH
« Reply #11 on: April 22, 2012, 06:40:19 PM »
Hi Nick.  The relay on the solenoid was probably put there to lessen the current through the ignition switch.  When I first started with my FC I had a similar problem.  If I gave the solenoid a thump with the blunt end of a screwdriver and all was well for a few starts.  From memory I found a dodgy riveted connection in the solenoid.  Possibly swap the solenoid for another ans see what happens.
zl296
« Reply #12 on: April 22, 2012, 07:13:00 PM »
probally out of brushes,,,,,,
 Wink
newman
The older I get, the faster I was !!!
« Reply #13 on: April 22, 2012, 07:17:55 PM »
 Wink
I redid the brushes in my FJ similar symptons, not saying its 100% the cause but it fixed mine Grin Grin and just in the nick of time as any longer left and I would have had to get the commutator machined Wink
Mick Cool
pbh0069
sa-club
« Reply #14 on: April 22, 2012, 09:20:37 PM »
had the same problem when i rebuild my 1979 harley, after two new batterys and still the same problem.
finally found a old school mechanic that straight away connected a second earth wire.
problem fixed ( its been 3 years and its never missed a beat )
might be worth a try Huh  Huh
phil.
Page created in 0.023 seconds with 17 queries.
