September 03, 2025, 06:57:04 AM *
Author Topic: Mechanical fuel pump for SBC  (Read 2964 times)
crowbar
« on: March 19, 2012, 06:00:03 PM »
Gents
Need your expertice yet again For 327 small block chev
The fuel pump I currently have is a Carter and it wont go on because it fouls with the subframe rail
Is there a smaller bodied one available. I have seen ones that look smaller on EBay
It is difficult being located in the bush because I cant walk into a shop and compare ( even the nearest super cheap is 80kl ms away
I dont want to go electric if I can avoid it
Haydn
« Reply #1 on: March 19, 2012, 07:05:13 PM »
carter runs below try this one its above.
http://www.ebay.com.au/itm/New-Small-Block-Chevy-Fuel-Pump-SBC-283-307-327-350-400-/190652021344?pt=AU_Car_Parts_Accessories&hash=item2c63befa60
zl296
« Reply #2 on: March 19, 2012, 07:28:57 PM »
go super cheap on/line....
 Wink
john253a
« Reply #3 on: March 20, 2012, 12:28:16 AM »
an reason you dont want electrical,
if its a safety thing, they make switches that run from dizzy to switch off fuel if engine stalls or fails (same as if LPG is fitted)
you can also run better fuel filters with electrical, and they can be fitted in line, engine bay or inside fuel tank
Good + Fast = Not Cheap
Cheap + Fast = Not Good
Good + Cheap = Not Fast
« Reply #4 on: March 20, 2012, 05:21:17 AM »
I went electrical in the EK wagon for exactly that reason - fuel pump fouled the chassis rails. I'm running a Holley Red mounted midships, and the noise is annoying... makes me wish I had run mechanical. Needs more work to shut the thing up (perhaps deleting a muffler might help  Grin).
I ended up going with a Peel Instruments safety switch (http://www.peelinstruments.com.au/page16.html) - cuts power to the fuel pump if there is no coil pulse, simple to wire in.
Harv.
crowbar
« Reply #5 on: March 20, 2012, 01:21:38 PM »
Thanks Gents
I would rather mechanical to keep things simple but if I have no choice electric it will have to be.
FC Hoon the pump on Ebay appears to be the same as I have (just pictured upside down) but there are some small bodied one's available on there also
I might take the risk and get one, it would be great if anyone has used one to be able to gauge the clearance from sub frame rail
Haydn
Page created in 0.029 seconds with 16 queries.
