September 04, 2025, 09:24:28 PM *
Author Topic: New Coil  (Read 6384 times)
Darren M
« on: March 11, 2012, 10:05:38 AM »
Hi all
Just wanting to know if i can put a petronix 40000 volt flame thrower coil on my 138 grey motor
Will it burn out points etc?
Cheers Darren.
john253a
« Reply #1 on: March 11, 2012, 05:48:23 PM »
yes you can, you are going to get there points replacement module
can't recommend it highly enough
if you dont want that coil you can just get a Bosch GT40
Good + Fast = Not Cheap
Cheap + Fast = Not Good
Good + Cheap = Not Fast
Darren M
« Reply #2 on: March 11, 2012, 08:11:44 PM »
Thanks John
I just have the coil and not the other bits to replace the points
is it still ok to use the coil.
cheers Darren
« Reply #3 on: March 11, 2012, 08:19:33 PM »
Check the coil is for 12 volt operation and not for 7 volt - grey motors use a 12 volt coil and reds use a 7 volt coil. So the coil you have must be to suit a grey motor, not a red motor.
Darren M
« Reply #4 on: March 11, 2012, 09:04:26 PM »
Thanks Ken,Will check
Cheers Darren
john253a
« Reply #5 on: March 11, 2012, 09:34:13 PM »
in the pertronix range i think its the 3 ohm coil you need,
but if it for a 6 cylinder i think they only sell 3 ohm
john253a
« Reply #6 on: March 11, 2012, 09:36:40 PM »
http://www.pertronix.com/prod/ig/flame/coils/chart.aspx
Darren M
« Reply #7 on: March 12, 2012, 08:54:31 AM »
Thanks again John
Yes it is 3ohm
I was a bit worried it would be to  powerful for my grey motor system.
Cheers Darren
john253a
« Reply #8 on: March 12, 2012, 12:16:35 PM »
its a very common upgrade Grin
Darren M
« Reply #9 on: March 13, 2012, 06:11:34 PM »
Hey John
Do you know any thing about wheel offsets for fc vans.
Looking at buying a set of 13x7 with 70mm back space and 0 offset.
Will they fit?
cheers Darren
john253a
« Reply #10 on: March 13, 2012, 06:54:56 PM »
nothing sorry mate
ken might know, as there connected to the brakes and his the guru on them
