August 19, 2025, 06:51:35 PM *
Author Topic: Manifold sealing  (Read 1496 times)
DN2168
See you on the road Skag!!
dean.nommensen
« on: February 01, 2012, 01:01:51 PM »
Is it worth putting anything on the manifold gasket when fitting to engine & if so what is best?. I have got some "Maniseal" here.
Dean.
« Reply #1 on: February 01, 2012, 05:03:30 PM »
No not really - the gasket will be fine by itself.
I have had trouble in the past with manifolds not being level. That is if you put a straight edge along the flanges, and the inlet and exhaust manifolds are not level. This means that the gasket continually blows out where the clearance is highest. If this is your case you need to either machine the manifold faces level or get another manifold.
