August 20, 2025, 01:24:29 PM *
Author Topic: tyres size problem  (Read 3385 times)
zl296
« on: January 20, 2012, 05:42:30 PM »
brought some american racing mags.
13x8inch  x4.
went looking for tyres...around gippsland...
not much luck.all to small
need 225/50/13,s
any idea,s around dandy area....
or someone knows somewhere... Tongue
John253a
« Reply #1 on: January 20, 2012, 11:28:16 PM »
why are you after low profile tyres?
a standard replacement for 6.40x13 in a 225 would be 225/60r13 or 225/65r13  to keep the speedo accurate
on the other hand i not most shop do a 225/55r13 as i use to run then on another car
zl296
« Reply #2 on: January 21, 2012, 09:15:28 AM »
they are going on ej van.
dont want any rubbing.
do you reckon higher proile will be ok....
dave.
John253a
« Reply #3 on: January 21, 2012, 05:42:28 PM »
cant comment on that as i dont have or no any one with one,
but i run 205/55r15 front and 225/50r15 rear on my fc and its lowered 40mm (15x6" rims)
and i only rub when i hit big bumps, witch isn't very often,
if you rim offset is correct they should fit if not look at 215/65r13
zl296
« Reply #4 on: January 21, 2012, 06:03:15 PM »
will search bigger tyre places....
see what they have... Undecided
« Reply #5 on: January 22, 2012, 01:47:06 PM »
Do a search on this forum or the FB/EK forum, I am sure this has been covered recently.
Page created in 0.024 seconds with 18 queries.
