September 09, 2025, 03:38:26 PM *
Author Topic: Tight Door Belt Fitting  (Read 3972 times)
KFH
« on: January 08, 2012, 07:59:04 PM »
Hi.  I recently fitted new door belts to the doors of my FC.  While doing so I found that the gaps at the top of the doors varied in width by a few millimeters from each other.  As a result of this the gap between the door belts on two of the doors have made the glass reasonably stiff to wind up.  They are clipped fully home, no excess paint behind the clips and the glass slides easily in the bailey channels without the door belt in.  I am using Rare Spares door belt Part # RDB1013 (this the front one) with a date of 14/09/07 on it.
Has anybody experienced this problem and how do you overcome it?  Two of the doors are really good.  Thanks
DN2168
See you on the road Skag!!
dean.nommensen
« Reply #1 on: January 08, 2012, 08:24:56 PM »
Hi Keith,
Maybe try some "Dryglide" spray on the door belt.
Dean.
« Reply #2 on: January 08, 2012, 09:49:25 PM »
The dryglide might help until the door belt wera in a bit. I would also suggest that you need to gently ease the top of the door frame apart to get a better clearance. This is ultimately the best solution but also difficult if you have fresh new paint. You could also try hammering the felt section of the door belt flatter so that their is more clearance
« Reply #3 on: January 08, 2012, 10:22:35 PM »
I have successfully eased opened the tops of the doors with out any damage to paint or panel by using a door pouch that locksmiths use looks like a lumber bag that goes in seats Huh Huh easier just search this ebay item you will get what I mean ...........FC427.......
Item number:   190589554021
« Reply #4 on: January 08, 2012, 10:26:32 PM »
Ebay Item #190589554021
Little bit of a discount going at the moment.
This may make it easier
Wayne b
KFH
« Reply #5 on: January 13, 2012, 10:36:02 PM »
Thanks for the replies.  When I get back home I'll investigate further.
« Reply #6 on: January 13, 2012, 10:58:20 PM »
These are available locally at Lock Smiths supply companies ......FC427......
moetstockie
« Reply #7 on: January 15, 2012, 12:09:58 PM »
I used a very large flat scewdriver between the door belts to (prise) widen the gap. As the others suggest don't go crazy or you'll damage paint like I did. The flocking on the belts will in time flatten a bit and give you more room. This was not an easy job. Moe`t
Page created in 0.033 seconds with 17 queries.
