August 05, 2025, 07:51:07 AM *
Author Topic: starter motor  (Read 8386 times)
zl296
« on: December 23, 2011, 10:37:13 PM »
can you use  a red motor starter on a grey....
OldGMHolden
« Reply #1 on: December 24, 2011, 09:18:01 AM »
I don't know about it fitting, but it would look really nice with yellow bolts. Grin
Gaz
« Reply #2 on: December 24, 2011, 10:48:07 AM »
I think you will find the red starter has two mounting bolts against the greys three, had a look at an old bell housing don't think it will fit in.
Regards Jim
zl296
« Reply #3 on: December 24, 2011, 11:06:57 AM »
l was told jim early red starter does go in....
interesting.
colt
« Reply #4 on: December 24, 2011, 02:13:51 PM »
Red starter does fit. You just use 2 bolts.
colt
zl296
« Reply #5 on: December 24, 2011, 03:35:02 PM »
bingo... Cheesy
« Reply #6 on: December 25, 2011, 10:23:11 PM »
Well there you go, didn't look like the same shape to me but glad to be prooven wrong, as they say nobody's perfect we just try hard to be
« Reply #7 on: January 17, 2012, 03:26:58 PM »
Guys,
No, you can't use a red motor starter on a grey motor, because the ring gear and starter motor pinion have a different number of teeth.  The red motor pinions and ring gears have more teeth.
The red motor starter will bolt up to a grey engine/gearbox, but when you turn the key, the teeth will grind and not engage.
The EH 149 starter motor is the same as the late grey starter, except with two bolt holes and a pinion to suit the red motor ring gear.
I don't know whether it's possible to fit a grey motor pinion onto a red motor starter.
zl296
« Reply #8 on: January 17, 2012, 05:00:33 PM »
need someone to find out if the armatures are the same as red starter/grey starter.
they can reco drives for them...
oldgrey58
South East Melbourne
« Reply #9 on: February 07, 2021, 12:10:36 AM »
Hi,
Following on from above, can a red motor armature be fitted to a grey motor starter and the grey pinion fitted to the armature to make it work?
And is it an simple job to change the pinion?
« Reply #10 on: February 07, 2021, 07:56:13 PM »
You can fit an EH 149 armature to a grey starter motor, but you'd need to fit the grey pinion to the armature.
In any other case, assume that a grey pinion can't be fitted to a red starter motor.  But I'd love to see it done . . .
« Reply #11 on: February 07, 2021, 08:04:14 PM »
Got me curious. A few years ago I helped out one of the local humpy lads (Squirrel). He had a red motor starter on the grey, worked fine (albeit I never saw it on the car). Took the car in to Mr Tedesco for service, who was not impressed. Scared Squirrel enough that he wanted a grey starter. I swapped him a grey motor one for his red one.
I too understood the red starter will hang off it’s two bolts and work on a grey. Might have to drag it out and check for myself.
