April 12, 2025, 03:39:47 AM *
Author Topic: m22 4 speed and 3.08 diff behind a grey  (Read 21639 times)
John253a
« on: December 21, 2011, 07:27:41 PM »
anyone done this before, does it fit in factory tunnel of does it need to be cut
resion i ask
factory box is 2.98:1 first with 3.888:1 diff
m22 has 3.74:1 with a 3.08:1 diff
put the take of about the same a factory but less rpm on fwy
John253a
« Reply #1 on: December 21, 2011, 09:14:25 PM »
or a w59 supra box and 3.7:1 diff
factory is around 3450rpm @100km
m22 with 3.08:1 2750rpm (same gearing in 1st as std)
w59 (0.85 od) 3.888:1 2950rpm
                    3.7:1 2800rpm
                    3.5:1 2650rpm
                    3.08:1 2350rpm (same gearing in first as std)
John253a
« Reply #2 on: December 23, 2011, 05:13:47 PM »
What combo's are others running,(rpm at 100, and does to take off well, hp of motor)
as i dont see the 3 spd crunch box handleing any sort of power incress,
i would to keep the coloum shift, for the stock look, but i dont think it will happern.
when i get around to the rebuilt, im aiming for around 150hp mark, nothing to wild (i drive a 450hp car as an everydayer)
200/204@50 400/415 lift 110lc cam(very small custom grind), 6.5:1 comp, 465 holley, toyota blower @ 3-4psi, twin exhaust
« Reply #3 on: December 23, 2011, 05:25:46 PM »
On a grey motor?HuhHuhHuh
« Reply #4 on: December 23, 2011, 07:28:02 PM »
Are you on the correct forum.   Cheesy A grey is a very small motor. Have you seen the pissy rods in them. What about an old Toyota four speed if ya wanna keep the column shift. Why jump to supra when a standard celica box is way over engineered for a grey.
zl296
« Reply #5 on: December 23, 2011, 07:28:27 PM »
leave some petrol for us over xmas....
 Cheesy
weddo
HIS, HER's & OUR's
billnjudiwedd@gmail.com
« Reply #6 on: December 23, 2011, 10:03:54 PM »
I'm with Ken,
"nothing to wild"  mmmmm Huh Huh Huh me thinks not. I can tel you from experience, if you want to go any where near 150 with a grey you are looking for "wild" and wild sort of money.
I had an M20 with a 308 diff  in one of my Fc's and you need to modify the whole top of the tunnel if you don't want to change to a larger tunnel. They are a good highway cruising set up, but the celica 5 speed with the 308 is a better one.
regards
Weddo
John253a
« Reply #7 on: December 24, 2011, 04:39:14 PM »
Am i trying to chase to much power?
Ive only ever bolted one of theis on a stock grey with a small pulley on crank so around 1:1 and boy did it liven it up
Felt like close to 100hp
im aiming for all low end power, with low revs on fwy
the cam and blower i already have, i plane on driving the blower at 1:1 (the is blowers make around 1psi per 1000rpm)
a 200/204@50 is only a 17/60 cam very small and all low end power(1200-3800rpm)
i do plane on a port/polish of the head but nothing off the top
i currently have a set of extractors but I'm looking for a set of good myers pipes that wont break the bank
the carby i have a 465 and 350 sitting at home and plane on trying to one of them
i dont want to cut the tunnel/modify as i dont plane on engineering it, so what ever is on needs to be able to go back to stock.
'fe350chev'
what mdl 4 spd is able to run column shift, and who does theis conversions
i spoke to rodracks and he only does the ausie 4 spd
and there a few modifying the colum shift for a full syncro 3spd box
my only other option is the 148 as under the new law i dont require a engineers cert to install it,
« Last Edit: December 24, 2011, 04:45:56 PM by John253a » Logged
« Reply #8 on: December 24, 2011, 08:47:05 PM »
I think you mean 149. With that motor you will get more power without a blower I think. Dellow probably have done four speed column conversions if u wanna stick with that. Parts all over for red 149. Keep the grey for changing back to stock
« Reply #9 on: December 24, 2011, 08:48:10 PM »
Nothing other than a grey is legal without engineers report now.
« Reply #10 on: December 24, 2011, 08:55:14 PM »
Wouldnt a 138 red be legal i have seen a few in earlly holdens still running stock front end and rear end and crash box ?
Think the 138 red came out in a turd runner (torana)
John253a
« Reply #11 on: December 24, 2011, 09:10:21 PM »
i have been told that the 138 red was optioned in the late fc
as my dad said his first car was a fc red
and a bloke i work with said he had one
ive seen no documented prof of this but being the same motor idd say no engineers is required either
i no of a lot stock/near stock 149 in fe/fc with no engineers and no problems
« Reply #12 on: December 24, 2011, 09:18:53 PM »
Do it then if ya can find one. Paint whatever you do in grey cops won't know  unless they are old
John253a
« Reply #13 on: December 24, 2011, 09:25:59 PM »
even if they are whats the bet they'll remember what a grey looks like
unless they still got one  Cheesy
« Reply #14 on: December 24, 2011, 09:28:27 PM »
The 138 was only in torries and exported hq's and johns fc  Grin Cheesy
OldGMHolden
« Reply #15 on: December 25, 2011, 12:08:35 PM »
No FC EVER had a red motor as standard, they are pulling your leg.
And don't think the cops are as thick as you make out.
Gaz
« Reply #16 on: December 25, 2011, 02:39:02 PM »
R u a copper  Cheesy Cheesy Cheesy
« Reply #17 on: December 25, 2011, 06:35:42 PM »
The red 2250 motor as Deano said was in the standard Torana's it was stamped as a 2.2 on the block. The first red motors 149 & 179 started in the EH holdens all motors before this where 138 grey sideplates up to the EJ
Regards Jim
« Reply #18 on: December 25, 2011, 08:35:53 PM »
http://holdenpaedia.oldholden.com/138_Red
John253a
« Reply #19 on: December 26, 2011, 09:46:26 AM »
As I said before I never seen any documented proof of it only have a few people tell me that back in the day they had red motors in there's, now it might not of been a 138 I never asked they just said red.
