August 22, 2025, 01:47:59 PM *
Author Topic: Tightening quarter vent.  (Read 2279 times)
Not Happy Jan
Aussie adventure
« on: December 08, 2011, 02:49:02 PM »
Is there a method to tighten up the quarter vent so it stays open when you are driving?? Mine keeps on swinging closed.
Nick
You can never have too many!
Port Macquarie NSW
« Reply #1 on: December 08, 2011, 03:16:16 PM »
stop whingeing at least you can drive yours lol.  Cheesy just kidding.
I took the time to take a pic for you. See where the bolt goes through, this clamps the shaft tighter to the rod and the hump think hold it there too. Maybe your bolt is loose or shaft is worn. the other one at the top just locates it and i dont think this end is your trouble.
Not Happy Jan
Aussie adventure
« Reply #2 on: December 08, 2011, 03:38:26 PM »
Thanks Deano
Will give it a tighten Grin
Port Macquarie NSW
« Reply #3 on: December 08, 2011, 04:00:47 PM »
a nice tight fit is what you want.  Wink
ACE
DOH!!!!!!!!!!!! !!!!
« Reply #4 on: December 08, 2011, 04:19:33 PM »
G'day Nick,
You probably need a new vent pivot kit.
Ebay item number 160445831642
Regards ACE  Cool
« Reply #5 on: December 08, 2011, 05:24:14 PM »
More likely is that the spring which surrounds the vent window shaft is broken - very common. New springs are available from R/S
If you remove the bolt and trapezium shaped clamp you should find an intact spring as shown in the photo - I'm guessing you won't.
« Reply #6 on: December 08, 2011, 05:30:35 PM »
a bit of silver solder would fill it out a bit if its not broken, but thats a bit of a dodgy way. ive seen worse, cardboard etc ha ha.
Page created in 0.034 seconds with 16 queries.
