August 22, 2025, 01:39:36 PM *
Author Topic: Offset on mags  (Read 2033 times)
Not Happy Jan
Aussie adventure
« on: December 04, 2011, 08:08:14 PM »
Hello everyone
I have a set of mags which I tried to put on the sedan today . The offset seems to be wrong as it rubs on the top control arm on full lock.
Is there anything that can be done to fix this? Spacers of some sort??or are they no good for an FC Huh Huh
I'm sick of changing wheels. Today I took the set of mags  off the wagon and replaced then, Then I took the cross plys off the sedan and put on the
mags  the took them off again as I changed the rear wheel cylinders and then put them back on, and I liked the look of it... ....then after the rubbing I took the mags off and replaced them with the cross plys again.  Tongue
Nick
You can never have too many!
Port Macquarie NSW
« Reply #1 on: December 04, 2011, 08:43:15 PM »
See if they rub on upper ball joint as standard HR were flat and aftermarket have the top bit for the grease to sit in i found a different brand op ball joints.
Not Happy Jan
Aussie adventure
« Reply #2 on: December 05, 2011, 08:19:17 AM »
Hi Pete.
it doesn't hit the ball joint it just knicks the tip of the rear  of the upper control arm and scrapes just under the lip/rim of the wheel.
Nick
Port Macquarie NSW
Not Happy Jan
Aussie adventure
« Reply #3 on: December 08, 2011, 02:47:03 PM »
 I guess I'll have to take the tyres off the mags and put them on some standard rims. Pity as I have 2 sets of the mags and both of them rub.
I might try the local tyre place first  and see if they have any ideas.
Port Macquarie NSW
« Reply #4 on: December 08, 2011, 05:09:56 PM »
I have 2 sets of mags here US racers and F90 simmons both bloody rub on the outer lip  Angry
