August 22, 2025, 01:45:53 PM *
Author Topic: clutch question  (Read 3020 times)
zl296
« on: December 02, 2011, 03:12:06 PM »
just setting up the clutch...
new master,hose,slave cylinder,all good...
clutch & presure plate still good,
free play in the clutch fork when push rod at slave adjusted right off,(bleeds ok)
when you push clutch.. piston in slave just about comes out,so adjust up works great..
but no free play,seems to be right free play at clutch pedal..
any ideas... Roll Eyes
« Reply #1 on: December 02, 2011, 05:22:11 PM »
Back the rod off under the dash on the pedal a bit so it not pushing out so far?
zl296
« Reply #2 on: December 02, 2011, 07:41:57 PM »
thanks hoon
will try
let you know...
zl296
« Reply #3 on: December 05, 2011, 11:34:39 PM »
is there a easy way to set up the gear linkages...
a photo of column to linkages,linkages to gear would be great...
« Reply #4 on: December 07, 2011, 05:28:26 PM »
No easy way, just the right way! - unless you follow the instructions in the manual you will find stiff changes or jumping out of gear common. Photos are all there.
