July 30, 2025, 08:26:11 AM *
Author Topic: HR V8 Front  (Read 2908 times)
FC_NUT
« on: October 12, 2011, 08:56:32 PM »
Hi all,
I was going to put a V8 in my FC Wagon but have changed my mind and using a red 6 instead, so I now have a modified HR front end to suit a V8 with a steering rack but no upper or lower wish bones,stub axles etc.
My question is what would it be worth to sell as is, as mentioned its just the modified cross member and the steering rack?Huh
Any info would be appreciated.
Regards Daimien
Daimien,
Carrum Victoria
FC-V8
Not enough hours in the day
« Reply #1 on: October 12, 2011, 09:10:10 PM »
Hi FC_NUT
Is the front end to suit a chev or holden v8 and is it a rear or front mounted rack?
Glenn
0401-065-201
FC_NUT
« Reply #2 on: October 12, 2011, 09:14:01 PM »
Hi,
I'm not sure what V8 its set up for and its a front mount rack, any idea how i could tell what the mounts are set up for?
Regards Daimien
Daimien,
Carrum Victoria
« Reply #3 on: October 12, 2011, 09:16:53 PM »
Why not use it with the red 6 ?
Or do you have another
FC-V8
« Reply #4 on: October 12, 2011, 09:21:07 PM »
Im not sure how to check the difference or if there is any difference between the two, Maybe ring Castlemaine rod shop to find out if they are different, if its a front mount rack is a good chance it is one of theirs.
Glenn
0401-065-201
FC_NUT
« Reply #5 on: October 12, 2011, 09:23:22 PM »
I do have another,
The V8 one has a section of the crossmember modified to suit a V8 sump I assume and what looks like higher than normal engine mounts.
Daimien,
Carrum Victoria
FC-V8
« Reply #6 on: October 12, 2011, 09:30:21 PM »
It sound more and more the a CRS one, I seen one sell on evilbay the other day for around $600.00 but it was complete except for disc's.
Glenn
0401-065-201
FC_NUT
« Reply #7 on: October 12, 2011, 09:34:28 PM »
Cheers Glenn
Daimien,
Carrum Victoria
Page created in 0.028 seconds with 15 queries.
