June 14, 2025, 12:19:09 PM *
Author Topic: Front Subframe Tie / Cross Member advice ?  (Read 2105 times)
old's kool
« on: September 09, 2011, 01:16:03 PM »
Hi Forum,
After some advice please?
I am considering an FE that has a crack in the Front Subframe Tie / Cross Member, I am yet to see a photo but I am told it is not due to rust.
I know there is a replacement panel. Is this member basically an un-bolt, and bolt back in item?
How involved would the replacement be? ie support of the front end, does the front end need to come off?
Thank you
« Reply #1 on: September 09, 2011, 09:14:17 PM »
This is a weld in piece and you would need to be competent to attempt it as it is a structural piece. It is unusual if it is cracked not due to rust - I would want to find out why it is cracked.
old's kool
« Reply #2 on: September 11, 2011, 07:20:04 PM »
Ken,
Thank you for your advice, much appreciated.
