August 25, 2025, 01:06:27 AM *
Author Topic: Rear Sway bars  (Read 3123 times)
Not Happy Jan
Aussie adventure
« on: August 24, 2011, 09:22:51 PM »
Just wanting to know if rear sway bars can still be purchased? and can they fit a wagon??
Nick
You can never have too many!
Port Macquarie NSW
« Reply #1 on: August 25, 2011, 11:42:01 AM »
Anything can be made to fit i have seen a few commodore ones fitted with some moded bracketry Huh
2door350
RAT 059
« Reply #2 on: August 25, 2011, 01:34:40 PM »
I used a selby HR one from memory - i was quite beefy, maybe 20 odd mm, i put some right angle brackets on the frame rails in front of rear wheels and mounted it to them.....not too difficult, mind you i have since taken it back off and prefer the ride without it...i would use a very small one if i tried another
2door350
« Reply #3 on: August 25, 2011, 08:19:17 PM »
I ripped holes in my rails when i had a HR one on there Huh just get a decent shock over a sway bar i reckon?
Pete
perth_ute
« Reply #4 on: August 26, 2011, 06:11:16 PM »
I bought front and rear from whiteline suspension. The result is amazing very stiff. They come with a mounting kit. I think the rear is 20mm and front is 28mm anyway the website tells you it all.
Not Happy Jan
Aussie adventure
« Reply #5 on: August 26, 2011, 06:55:54 PM »
Thanks All
Might just get a good set of shocks as you say Pete
Port Macquarie NSW
« Reply #6 on: August 26, 2011, 08:28:00 PM »
I ended up taking my rear sway bar out as our roads are horrible and it just made the ride rougher but when i fitted a good set of shocks i ended up cracking the top shock mount.. Angry
