August 25, 2025, 01:34:17 AM *
Author Topic: rear mounted rack  (Read 3634 times)
freddyc
« on: August 18, 2011, 07:58:57 PM »
Can someone tell me the measurement from mount point to mount point on a shortened vb/vk commodore. I bought a front end and I think it has not been shortened.
thanks fred
Townsville North Queensland
« Reply #1 on: August 19, 2011, 08:40:44 AM »
they are very short mines in the back of the shed but at a guess 350mm ish centres
 the centre tube between the 2 alloy housings is only around 60mm
 your nuckles on the rack should pivot where the lower control arm pivots so you dont get bump steer.
Have seen a few shonky ones where they just shorten the rack end really short and they will steer horrible.
can take a photo if you would like.
Pete
freddyc
« Reply #2 on: August 19, 2011, 10:09:44 AM »
Mine is 360mm between mount points and 120mm between alloy housings. And yes to photos
regards fred
« Reply #3 on: August 19, 2011, 05:19:11 PM »
they can vary whoever modified it
OK mine 290 centres and 50 in the guts.
Pete
freddyc
« Reply #4 on: August 19, 2011, 06:30:55 PM »
I don't know who modifeied mine if at all, the pivot point of the rask is about 50mm outside the pivot point of lower control arms. This tells me I will have all sort of steering problems.
fred
« Reply #5 on: August 19, 2011, 06:38:02 PM »
post a pic or send me one to post might not even be commodore or modified.
 you would know if its a commodore they are long as hell.
Could be a camira as they are pretty popular but then again it  could be anything //
My old man set up a torana one on the rear of a hr  crosmember in his T tudor it was in their for ages and i jumped in it one day and turned left and the wheels went right very important lesson learnt.
