September 09, 2025, 03:41:53 AM *
Author Topic: V6 into FC  (Read 7438 times)
freddyc
« on: August 02, 2011, 04:19:13 PM »
I am fitting HR front end with HQ stubs and discs, STD HR drum brake rear. I have a gemini booster. (a) will the booster fit in between engine and motor? (b) will it have enough boost
regards fred
Townsville North Queensland
« Reply #1 on: August 02, 2011, 08:56:25 PM »
Engine and motor?? Or engine and subframe? if its the latter then have a look at mine with the VT booster.
freddyc
« Reply #2 on: August 03, 2011, 07:06:50 AM »
DER, I won't start the engine vs motor arguement again. Engine and bonnet hinge.
« Reply #3 on: August 03, 2011, 07:22:11 AM »
I think that the gemini booster is a lot smaller in diameter than the VT booster, so will fit, but as ofr  the stopping power I can't tell you... Ken will be the man to give this advice.
FC_fer_me
baby boomers luv FC's
« Reply #4 on: August 05, 2011, 03:39:47 PM »
I used a VR booster on mine and it just cleared the bonnet hinge. I had to modify the spacer bracket to make the reservoir level but by using the original brake cylinder hole the pushrod for the VR booster lines up perfectly with the original brake pedal arm just necessitating a new hole being drilled thru the arm. Have a look at my build there are a couple of photos of the booster. http://fefcholden.org.au/forum/index.php/topic,12539.0.html
freddyc
« Reply #5 on: August 05, 2011, 04:02:47 PM »
when you say lines up with brake pedal arm, did you use original FC brake pedal and support and modify foot on that, or use the commodore bracket and pedal
FC_fer_me
« Reply #6 on: August 09, 2011, 07:52:41 PM »
Hi, I used the original brake pedal and support and just welded the larger pedal pad over the top of the original one. This should keep your engineer happy too. Cheers ,Jack
« Reply #7 on: August 10, 2011, 08:25:07 PM »
The good thing about Commo (and other) booster mounting to the pedal is that they mount to the side of the pedal rather than directly in front of the pedal like the original master cylinder.
This means that you can move the booster about 10mm away from the bonnet hinge from centre if you use the original Commo mount system. On the other hand a smaller booster can be moved away from the clutch master if you are using a manual gearbox.
FE 4 ME
"A Sweet Sensation"
« Reply #8 on: August 10, 2011, 08:55:11 PM »
Boy Ken you sure know your stuff..you should write a book...let me know if you ever have or will and i will be there to get it signed by "The Guru "
thankx always for your input
FE 4 ME
freddyc
« Reply #9 on: August 12, 2011, 05:29:42 PM »
I have a PBR b258-058 booster and master cylander what model is this out of, google says VT is this same as VR/VS?Huh and will this suit what I wish to do
