September 08, 2025, 10:53:38 AM *
Author Topic: Brake Boosters  (Read 10268 times)
« on: June 23, 2011, 03:22:41 PM »
Anyone know of a dual circuit firewall mounted booster from a popular make/model that will suit a HR braking system and still allow the clutch master cylinder to fit on the firewall. I fitted an LC/LJ Booster last time around, but I'd guess that they are getting expensive now  Undecided
fc2360
« Reply #1 on: June 23, 2011, 07:27:35 PM »
hi Stinky I know of an ek with a chev in it which was engineer about a month ago mazda  323 dual cylinder no booster hq caliper front ford drums rear stops without alot of pedal effort plenty of room on fire wall and the cylinder was under $200 new.he has just posted about his car on ek forum (old tin hunter)
reguards geoff
FCGos
« Reply #2 on: June 23, 2011, 08:15:51 PM »
Stinky the Datsun 180B booster is small in diameter and will provide sufficient vacuum assistance, not 100% if it will fit but it is one of the smallest I know of.
http://www.datsport.com/products/images/brake-booster-master-small.gif
way66
« Reply #3 on: June 23, 2011, 08:50:56 PM »
Hello
I had HR with a HZ dual Circuit master cylinder using a crs mount kit & a HR clutch master cylinder , a vh40 booster, only the front brakes were boosted , HR front disc & HR rear drums ,
REGARD WAYNE
GMB-58FC
Stage one complete...
« Reply #4 on: June 23, 2011, 09:17:35 PM »
Stinky when you've made up your mind on what you need give me a yell, I should be able to save you a few dollars (better than trade)  that goes for anyone needing brake/clutch parts on here Cheesy
ABS Hobart- 6231 5855
PM FOR QUOTE
« Reply #5 on: June 24, 2011, 06:59:42 AM »
I run Datto 180B with commodore cylinder for commodore brakes but you could run datto master cylinder.
« Reply #6 on: June 24, 2011, 08:18:24 AM »
Stinky have a search " SHOW US YOUR BOOSTER " I started this a while back so it would be easy to search different options of boosters  and show pictures  .....FC427.......
« Reply #7 on: June 24, 2011, 11:31:11 AM »
Interesting...  I just bought a 120Y booster for my 1200 project... looks very similar to the 180B.  Except the MC bore size is different?
Old Mazdas also have small boosters.
Rusty EK
« Reply #8 on: June 24, 2011, 12:24:23 PM »
What about a Holden Gemini booster , they are pretty compact
