August 22, 2025, 07:44:09 PM *
Author Topic: Vacuume Wipers  (Read 4928 times)
graham_fuller
« on: June 14, 2011, 11:33:03 PM »
Any suggestions as to why my wipers would work for about 10mins and then stop? They will then restart after turning them off and giving them a rest period .
jack_fc
SouthWest Coast, Victoria
« Reply #1 on: June 15, 2011, 10:07:01 AM »
Graham,
I'll be very interested in any answers you get on this one as I have exactly the same problem....
(I'm assuming it's caused by old age in my case  Wink)
cheers, jack
« Reply #2 on: June 15, 2011, 10:17:56 AM »
Jack,
I would have thought that you would have electric wipers on yours?  Huh
jack_fc
« Reply #3 on: June 15, 2011, 10:30:43 AM »
You're right, Keith; my wipers are electric and work fine....
CraigA
« Reply #4 on: June 16, 2011, 01:19:25 PM »
Is it possible that the control cable is vibrating backwards over that time, closing the valve in the vacuum motor?
So when they stop can you restart them by turning the knob on the dash?
Alternately it could be the seal inside the motor itself. The paddle that is driven by engine vacuum could be worn and get worse as it heats up through use.
This guy http://www.wiperman.com rebuilds them.
Ficken Wiper Service
132 Calvert Ave
West Babylon, NY 11704
(631)587-3332 M-F 9-5 EST
Robert Ficken
sales@wiperman.com
graham_fuller
« Reply #5 on: June 16, 2011, 01:30:48 PM »
Hi Craig,
No the cable couldn't be loose as its tight to switch on. The internal blade could be the problem i guess. Its not in perfect condition. I will disassemble and see what i find.
« Reply #6 on: June 16, 2011, 09:32:26 PM »
If the cable is tight that would be your problem, the cable is only just turning the wipers on and then a little bit of vibration is relaxing the cable and it turns off again. Take the cable out and lubricate it. Lubricate the switch slider as well.
Gertie
Grey & White rooles
« Reply #7 on: July 14, 2011, 07:30:42 PM »
I would check the vacuum hose that connects to the wiper motor. My original hose was partially blocked. I replaced it with another hose, it wasn't strong enough and partially collapsed when the vacuum was applied. The new one has thick walls and works OK.
