May 24, 2025, 01:19:36 PM *
Author Topic: hr front end proplems  (Read 2861 times)
clivetitchener
« on: April 29, 2011, 09:17:53 PM »
hi guys i have an fc ute i have installed an hr front end and have stayed with the old grey motor i used the fc out rigger and i have completely replaced the steering components with hr parts the problem is now the sump position is to low do i need to change the sump for some other model or do i alter the origanal all help would be greatly apprecated
« Reply #1 on: April 30, 2011, 10:00:22 PM »
Using the FC outrigger was your mistake - use an FB EK or EJ outrigger. It will get the engine at the right height. The HR steering gear does just touch the grey sump on full lock - it's better to use the FC steering gear if you have the grey engine, other wise you need to modify the sump a little bit.
clivetitchener
« Reply #2 on: May 01, 2011, 10:31:59 AM »
hi ken thanks for the replay i assumed i would need the old fc out rigger i will now try again cheers clive
« Reply #3 on: May 01, 2011, 10:38:59 AM »
What about an EH outrigger?
Rgds
Wayne B
Stewy
sa-club
Jeff Stewart
« Reply #4 on: May 01, 2011, 11:13:34 AM »
Hi Wayne,
I think it is because the EH was the first of the red motors and is not right for the mighty grey.
Cheers Stewy   Cool
« Reply #5 on: May 01, 2011, 09:01:24 PM »
That's right - there is no front engine mount spot on an EH outrigger
