July 27, 2025, 05:41:47 PM *
Author Topic: 1963 EJ Holden Sedan with full reg and RWC.  (Read 2493 times)
ozfueler
« on: April 27, 2011, 09:59:40 PM »
Holden EJ 1963 manual Sedan $10,600.00
Nice unmolested clean early Holden with Grey 138 ci motor, it has mag wheels and also comes with original steel wheels and hubcaps.
The car is registered to December 2011 and has a Victorian RWC
General Information
Car drives like a 1963 Holden should, the brake booster makes the brakes excellent. The EJ runs happily on 91ron unleaded fuel, without the need for lead additives due to new hardened head seats.
I have spent over $3500 on mechanicals to make this car reliable and fun to drive.
New parts.
Radiator core, Top and Bottom Radiator hoses, Heater hoses. Thermostat housing, Thermostat, Radiator cap, Fan belt, Brake booster, Master cylinder, Slave cylinders, Brake reline, Machined brake drums, Brake hoses, Spark plugs and Leads, Electronic distributor kit, Coil, Four shock absorbers, Muffler, Tail pipe, Fully reconditioned Head with Hardened Seats, Valves and Guides, Rear Shackle Bushes, Handbrake cable, Indicator Flasher can, Wiper rubbers, Clutch and Brake Rubbers, Indicator and Stop light lenses, Floor Carpet (Knox carpets), Rust Repairs and paint, Wheel alignment, Windscreen Washer kit (wired to wiper control )
The car has had new floor pans fitted at some stage and is almost rust free, there are some small bubbles on one rear wheel arch only.
Everything works on the car, it will be sold with a full Victoria RWC.
The are two bad points, a small tear in the back of front seat, and the rear seat has some splits which will need redoing, otherwise, it’s all done ready to just go cruising and enjoy.
Car can be viewed at Melton or I can supply photos on request.
For more information ring Graham 03 9743 2276 ( Melton. VIC )
