September 07, 2025, 11:35:22 AM *
Author Topic: 'N Walker & Son' Grey Motor Marine Manifolds  (Read 7022 times)
THOMMO_2
FB-EK Car Club of SA
« on: April 15, 2011, 06:29:47 PM »
Gday All
I am looking for a 'N Walker & Son' Twin Carb Manifold & Matching Water Cooled Twin Exhaust Header,
to suit a grey motor for a boat. These manifolds are Marine Use Only.
You can notice on the bottom photo, the angled carb mounting faces on the manifold would have the carbys leaning backwards
if fitted to a car, on my boat the manifold is on the other side of the motor (because the motor is backwards & tilted on a greater angle) so
this has them pointing up in the right direction.
Any leads on this items greatly appreciated  Cool
Jeff
USE IT OR LOSE IT
« Reply #1 on: April 15, 2011, 10:54:03 PM »
Hey Jeff
I don't have what you need, but thank you for posting the pic and info.
I did not know that set up existed before.
Good luck with your search.
Dave88
« Reply #2 on: April 16, 2011, 10:10:04 PM »
Jeff,
I can't help either, but I did see one of those inlet manifolds on a midget speedcar last year. The extra long runners caught my attention.
Good luck in your search
Dave88
« Reply #3 on: April 16, 2011, 10:16:10 PM »
By the way... if it's a timber boat you're working on, you might like to check this site out and post a wanted add on there bulletin board
http://www.cawpba.com/
ashfe
« Reply #4 on: April 18, 2011, 07:26:55 PM »
i have a grey motor that has been mrinised come out of old clinker hull that was upgraded to a 202 i think it is a single or triple setup it at mates house will check tommorow it was just picked up as spares
THOMMO_2
« Reply #5 on: April 18, 2011, 08:36:50 PM »
Hi Dave88, I am from the cawpba site, but thanks for the tip Wink
The single/triple set up would be a tawco manifold Ash, its a single/twin actually.
The carb mount flanges are too close together to be used as triples.
Tawco's are as common as bums, almost standard equipment as far as marinising goes.
If the manifold is not a tawco though, I would be interested to find out what it is.
Please check it out.
Thanks for the replies fella's Cool
Jeff
USE IT OR LOSE IT
Stewy
sa-club
Jeff Stewart
« Reply #6 on: May 12, 2014, 10:05:29 PM »
Hi Thommo,
I know it is only a single carby but I thought you might be interested.
Ebay Item #271485566891
Cheers Stewy   Cool
