July 21, 2025, 04:57:10 AM *
Author Topic: Guard upper bolts/nuts  (Read 4603 times)
« on: March 18, 2011, 07:35:58 PM »
trying to locate the non obvious bolts, im sure this has been dont to death, can someone point me to a good post pls?? Huh
FCV08
FE FC Club of QLD
« Reply #1 on: March 18, 2011, 09:08:14 PM »
Hope this helps
Three bolts in inner side of A pillar - One in over top of upper hinge from inside the other two are further down the A pillar. You will see a access gap in this pillar that allows a 1/4 or 3/8 inch type sockets and extension. Not sure of exact size  Roll Eyes Roll Eyes Grin
The majority of the others are easier to access.
Craig
« Reply #2 on: March 18, 2011, 09:43:43 PM »
its the top one thats not so obvious, the others stick out more cos the access point have to go somewhere  Angry made me bit grumpy  Angry Angry Angry
« Reply #3 on: March 18, 2011, 09:47:43 PM »
As Craig said - use a 3/8 drive socket set with extension handle - it fits perfectly. If you use a 1/2 inch drive socket it will not go on the bolt
« Reply #4 on: March 18, 2011, 09:49:37 PM »
Thanks guys, Everything is too original on this thing ha ha.
« Reply #5 on: March 19, 2011, 11:22:56 PM »
I thought id leave the easiest til last but it turns out once located, i used a 10mm 1/4 in extension to reach them easily but the lhs bottom on is in a bit of an angle and looks to be in very poor condition. This one may need some convincing and doesnt want to play fair with the bendy 3/8 adaptor. might have to find my 1/4 bendy/uni thingy. funny how they are so small and very fine thread. are there any ones at the front that i might have missed?
FCV08
FE FC Club of QLD
« Reply #6 on: March 20, 2011, 08:00:58 AM »
From memory there are at least two screws that join the guard to the front section under the grill. There may also be some that attach to the side of the grill assy. Other than that there are the two bolts that hold the lower guard in place down under the sill. Hope this helps.
There shouild be no more to remove from the inside if you have removed the three bolts.
Craig D
« Reply #7 on: March 20, 2011, 10:35:07 AM »
that did help thanks, u know when u get to the point your not sure if its a bolt or just being stubborn getting it off.
