August 23, 2025, 06:24:40 AM *
Author Topic: temperature gauge wiring  (Read 4249 times)
FC229
« on: February 28, 2011, 09:15:14 PM »
Hi All,
I have a VDO temp gauge and sender I would like to fit to the wagon. It has a 2 pin connection, one marked B and 1 marked S....(sensor??) Can anyone tell me what to connect to the sender / sensor, and what the other goes to? The Gauge I have currently has 1 power, 1 to the sensor, and 1 earth. I can only assume the gauge earths through it's mounting. If anyone has something similar and can point me in the right direction I would be most appreciative, not sure if trial and error could wreck the gauge??
David.
« Reply #1 on: February 28, 2011, 10:23:36 PM »
Some helpful PDFs here - http://www.egauges.com/Inst_PDF.asp
If there are only two pins, I would assume earth is through the gauge body. S for sender and the B for power, not sure what B would actually stand for though  Huh
newman
« Reply #2 on: February 28, 2011, 10:26:42 PM »
Battery  Huh can't think of any thing else.
CraigA
« Reply #3 on: February 28, 2011, 11:12:34 PM »
Those meters just measure current flow.
Only two pins needed, as suggested one to battery +ve, one to sensor, sensor body is earthed.
There's your circuit.
If it's VDO then they typically use a 30ohm sensor.
Unusual for it not to have a backlight though?
CraigA
« Reply #4 on: February 28, 2011, 11:14:35 PM »
Oh, and if you connected the B to battery +ve and the S direct to ground you will most likely blow the crap out of it. The sensor limits the current through the gauge.
FC229
« Reply #5 on: March 01, 2011, 06:30:34 AM »
Thanks eveyone for the replies, B for Battery makes sense, I'll give it a go
