August 05, 2025, 05:24:49 AM *
Author Topic: Vent Cowel removal  (Read 2241 times)
Old_Mt_Isa_Boy
My Ute
« on: February 12, 2011, 06:41:52 PM »
Is there a trick to removing the cowel?  Huh Does the link shaft have to be removed? Just seems a bit awkward and do not want to break. A reference to a page in the manual would be fine, i cannot see it in there.
Thanks in advance if anyone can help.
Rgds
Wayne
graham_fuller
« Reply #1 on: February 12, 2011, 06:52:22 PM »
Hi Wayne,
Yes i have always removed the link shaft first then the 4 screws, and then lift it out. I don't know of any other way, it is a close fit.
Stewy
sa-club
Jeff Stewart
« Reply #2 on: February 12, 2011, 08:31:20 PM »
Hi Wayne,
I did mine on the donor FC wagon this afternoon. It is on page 27 of the workshop manual under Front End Ventilator
A bit of wd 40 spray on the nuts high up under the dash and on the control handle thread. then unscrew anticlockwise,
i put a small scdewdriver through the hole to unwind it because it was tight all the way down the thread.
then undo the 4 nuts and bolts ( 2 each side) then lift out.
hope this makes sense
Cheers Stewy    Cool
Old_Mt_Isa_Boy
My Ute
« Reply #3 on: February 12, 2011, 08:46:32 PM »
Makes sense now, Thanks guys.
Rgds
Wayne
