May 26, 2025, 08:48:41 AM *
Author Topic: Wipers are binding  (Read 2342 times)
FATBOY
« on: January 18, 2011, 09:39:09 PM »
Ive installed a preslite wiper conversion .When i turn the switch it binds up on the cam (from a ek).Do i have to use fb ek arms ??
regards fatboy
fatboy
0414712441
« Reply #1 on: January 19, 2011, 02:37:41 PM »
You have to use the 2 short links from the back of the EK wiper motor - these are hooked up to the original long FE FC arms
JesseLMackey
JesseLMackey JesseLMackey JesseLMackey
« Reply #2 on: February 09, 2011, 07:37:00 PM »
If the car is a few years old, there's a strong possibility that the
bearings at the base of the wiper blades are dry and/or seizing. It's
pretty easy to tell. Lift your wiper blades off the glass and turn the
wipers on. Watch the housings where the blades attach to the car. If the
housings twist as the blades move, the bearings are seizing and in need
of lubrication. Park the wipers, then take off the wiper arms. Remove
the rubber seals covering the wiper arm bearings and work some oil
(don't use thin spray lubes, they don't last long enough) in between the
shafts and the housings, then turn the wipers on. Continue to add oil as
it works its way into the bearings. When the shafts turn freely in the
housings, you're all set and you can reinstall the wiper arms. You'll
probably hear a difference in the wiper motor sound when the bearings
loosen up.
Jesse L. Mackey
Page created in 0.048 seconds with 18 queries.
