August 05, 2025, 05:22:10 AM *
Author Topic: Rubber connector for the fuel tank  (Read 3564 times)
steamman
Woodend Victoria
« on: January 04, 2011, 08:02:56 AM »
Doe any body know if the rubber connector between the fuel filler and the tank on an fe ute is reproduced by any body?
Rare spares don't seem to.
FE and FC"S rule.
« Reply #1 on: January 04, 2011, 04:21:07 PM »
Supercheap have turbo intercooler silicone hoses in all shapes and sizes ..
or pirtek have industrial hose you could get some of that...
steamman
Woodend Victoria
« Reply #2 on: January 04, 2011, 07:27:40 PM »
I,ll give pirtek a go and see what i can turn up.
FE and FC"S rule.
« Reply #3 on: January 04, 2011, 08:39:19 PM »
Pirtek make sure you take a big fat wallet with you...
New hose for my pressure cleaner at work 2 fittings on the end 398 bucks Sad
« Reply #4 on: January 04, 2011, 09:21:33 PM »
Do you mean the insulator between the pipe and the body?
There is no rubber pipe connector between the filler and the tank on the ute - if you have one, it is because it was done by someone at some time. This would be why Rares dont list it.
« Reply #5 on: January 04, 2011, 09:29:22 PM »
You could probably use one from an LC/LJ Torana.
steamman
Woodend Victoria
« Reply #6 on: January 05, 2011, 10:20:55 AM »
HMMMMMM looks like the filler pipe on my fuel tank has been cut at some stage.
Here a photo it may shed some light on the issue.
FE and FC"S rule.
CraigA
« Reply #7 on: January 05, 2011, 10:30:51 AM »
If you want a new one of those hoses then Stinky is spot on - an LC/LJ one will fit and is available via eBay or Rares.
I just fitted one to my XU1 on the weekend.
American Autos in Sydney list some for F&8ds that may also fit. Search "FUEL FILLER NECK JOINER HOSE" on http://www.americanautos.com.au
