September 09, 2025, 03:22:21 PM *
Author Topic: Funny heater tap on hose above fuel pump  (Read 7655 times)
« on: December 09, 2010, 11:01:29 PM »
Hi
i have a barn find FE Im gunna restore which i just purchased. It has a funny looking rural type tap near the pump housing. It has what is hard to tell if its an original heater demister, cos looks rudimentary, but I think it is original with a little flap u can open from passenger side.
Whats the go with this.
Deano.
« Reply #1 on: December 10, 2010, 05:33:43 AM »
Any names on it nasco, warmaride, smiths, JAP,
there was a lot of aftermarket stuff around in the fifty,s
take a pic and post it if you have trouble send it to me to put up for you.
mallaby1@bigpond.com
Pete
« Reply #2 on: December 10, 2010, 04:36:44 PM »
Bit busy with all the christmas stuff on at moment. and we got a bit flooded this way lately, Ill see if I can find it tonight. Why cant u just upload things from this site, why u need photobucket?
« Reply #3 on: December 10, 2010, 05:45:19 PM »
here is the funny tap
« Reply #4 on: December 10, 2010, 05:57:13 PM »
Well, going by the colour of it, it's brass!
Not a standard tap, often they were switched on in winter and turned off in summer and were cheaper than buying the "factory" cable operated tap.
« Reply #5 on: December 10, 2010, 06:19:39 PM »
looks like a 50,s hardware job.
i use a ball valve very rarely drive in winter.
Maco
« Reply #6 on: December 10, 2010, 08:06:33 PM »
I would say the valve is a 90' shut off valve, nothing special.
Better in Green
« Reply #7 on: December 10, 2010, 11:00:41 PM »
yeah was confirmed tonight as nothing and cable operated ones explained. And the heater has "Smith's" brand on it. so that isn't original I don't think but still a very old example.
« Reply #8 on: December 11, 2010, 07:22:27 AM »
Its a period accessory and id rather that than no heater.
« Reply #9 on: December 11, 2010, 06:46:36 PM »
owned man
« Reply #10 on: December 11, 2010, 07:34:56 PM »
owned man
me that is (owned), but i really didnt think it was original....seriously lol.
graham_fuller
« Reply #11 on: December 12, 2010, 07:17:36 AM »
As FCHoon said a standard aftermarket period accessory.
« Reply #12 on: December 12, 2010, 08:34:51 AM »
Because the engine runs (doesn't drive cos Clutch system needs bleed and rear brakes disconected) do you think i should test it. I think when the paddock dries out I should give the motor a good run blow the cobwebs out and give the lifters a run too wouldn't hurt. It was started afters a year sitting there with no noises or smoke or anything.
I will have a bit of time in the leadup to Xmas to start stripping her.
« Reply #13 on: December 13, 2010, 08:24:58 AM »
watch runnign your heater the problem with heaters is greys are only meant to 6lb radiator cap and reds and jap motors run a lot more pressure and they leak.
if the grey ran in the shed you are only ripping it out anyway?
« Reply #14 on: December 13, 2010, 09:40:52 PM »
I couldn't wait any long Hoon, I just started stripping the bastards tonight!  Shocked Grin
