August 23, 2025, 03:57:37 PM *
Author Topic: Right fuel for FE grey motor ?  (Read 4530 times)
Townee
« on: October 17, 2010, 08:05:47 PM »
Just in the process of buying an FE Holden and before I went through with it am looking for advice on what fuel to use and also if additives are required.
I am in NSW so my options are becoming limited.
Regards Townee
Townee (NSW}
Paul In Ireland
« Reply #1 on: October 17, 2010, 10:38:05 PM »
I use unleaded with an additive - maybe this one has already had the valve seats hardened and then you wouldn't even need the additive.
fe-ambo
« Reply #2 on: October 18, 2010, 05:45:33 AM »
I use premium unleaded with Flashlube additive in my old cars.
Paul
If take a ride in a ambulance you gotta a chance,
if you take a ride in a hearse its gotta be worse.
Check out this website for more photos
http://gallery.oldholden.com/hr-hearse
« Reply #3 on: October 18, 2010, 02:33:41 PM »
I run a valve lube bottle thingo and every now and then i put some lead additive in the tank for a bit more re assurance.
mickusmickus
Brisbane, Queensland
« Reply #4 on: October 18, 2010, 02:54:42 PM »
Fuel Additive and Premium Unleaded for me as well!
I have read posts here and also on other forums that people only run additive every 2 or 3 tanks, but I use it in every tank.
Townee
« Reply #5 on: October 18, 2010, 07:23:57 PM »
Hi and thanks to all that responded.
I am now clear on what I need to do.
Regards Townee
 Grin
Townee (NSW}
fastjbav6
OK start her up !
« Reply #6 on: October 21, 2010, 12:57:04 PM »
I use standard unleaded fuel and pour Flashlube in the tank at every fill.
I read somewhere that standard fuel can be used on engines with a compression ratio of 8.86:1 or less. Premium fuel is ideal for higher compression or performance engines.
Seb
Yellow Knight
« Reply #7 on: October 21, 2010, 05:35:03 PM »
Seb
You must make sure that you do use a valve additive (or upper cylinder lubricant which has an additive in it) unless the head has hardened valve seats installed.
F4+ Wink
Page created in 0.054 seconds with 17 queries.
