September 03, 2025, 01:21:07 PM *
Author Topic: Stainless Steel Pistons for Brakes  (Read 3331 times)
KFH
« on: September 25, 2010, 10:03:09 PM »
I had a mate of mine turn some stainless pistons up for my brakes.  The cylinders have be relined with stainless also.  Should I use rubber grease or just brake fluid when I reassemble them?  My experience with rubber grease is that after several years it goes gooey.
FC_fer_me
baby boomers luv FC's
« Reply #1 on: September 27, 2010, 08:05:45 PM »
Keith, most workshop manuals suggest soaking rubber seals in new brake fluid before assembly. Cheers, Jack
KFH
« Reply #2 on: October 01, 2010, 01:25:17 PM »
Thanks Jack.  I'll go that way.
Maco
« Reply #3 on: October 01, 2010, 07:55:39 PM »
I could be incorrect but I don't think you should run the same type of metals together as they will 'pick up', me be some of the gurus can advise.
Better in Green
« Reply #4 on: October 01, 2010, 09:35:18 PM »
Good question John Huh Huh most calipers even after market [Willwood, Outlaw ] etc use an aluminium body with stainless pistons.. OME use Aluminium or castiron bodies with stainless pistons.. Keith better do some research ....FC427....
Old_Mt_Isa_Boy
My Ute
« Reply #5 on: October 01, 2010, 09:43:00 PM »
Where's Ken Cool If he doesn't know where all in trouble.
Rgds
Wayne
« Reply #6 on: October 02, 2010, 08:43:15 PM »
I'm here,  Grin
You shouldn't put similar metals together.
I have seen original cast iron cylinders with steel pistons and these seem to work OK. Both the aluminium and steel pistons corrode when they get dry.
I think I would use aluminium pistons in stainless sleeves rather than stainless steel.
I personally would use rubber grease as well since most damage is done when the piston to sleeve interface goes dry rather than a little gooey.
