July 18, 2025, 06:54:15 PM *
Author Topic: Bearing Bridges  (Read 5595 times)
weddo
HIS, HER's & OUR's
billnjudiwedd@gmail.com
« on: September 13, 2010, 09:35:16 PM »
Wanted - set of bearing bridges for grey motor project shhhhh
regards
Weddo
« Reply #1 on: September 14, 2010, 09:35:30 AM »
I'll bite Weddo, can't help with the bearing bridges but where did you find the Repco Highpower head set up  Huh
Oh, & if you know of another ............
Gary
« Reply #2 on: September 14, 2010, 10:44:35 AM »
They still make them for sidevalve F##D you might be lucky and the bolt centers might be the same  Huh Huh.......FC427......
weddo
HIS, HER's & OUR's
« Reply #3 on: September 14, 2010, 01:20:27 PM »
Hi Garry,
I don't know of any others that are for sale at the moment. I can't divulge where I puchased mine as agreed with the vendor, but will later on when the project is complete.
I can tell you that the head is complete, came with extractors (will need to refabricate to suit FC) inlet manifold to suit twin barrel side draft solex S40, and two solex side draft carbs. Need some minor refurbishing to the head ie hardend seats, maybe valve guides as a precaution and same with rocker arm sleeves. I will need to adjust the mountings for the carbs as they are not original.
regards
Weddo
weddo
HIS, HER's & OUR's
« Reply #4 on: September 21, 2010, 12:20:06 PM »
"Bump" for bearing bridges - anyone?
regards
weddo
coolaride
« Reply #5 on: October 01, 2010, 11:48:21 PM »
pm sent ..
fjuteman
« Reply #6 on: October 13, 2010, 08:34:15 PM »
I'm also after some bearing bridges, plus mild cam,with alloy gear !!!
« Reply #7 on: October 14, 2010, 12:06:49 AM »
To all those that are looking for bearing bridges, one alternative that used to be quite common amongst the speedway fraternity was to machine the bearing caps level with the bolt face and then fit ( IIRC) 1 and 1/4 x 1 and 1/2 steel blocks on the caps with longer bolts.
This stiffened up the bottom end and stopped the cast bearing caps from stretching. Another more expensive alternative was to get some steel main bearing caps (which were also available aftermarket) and have them machined to suit the engine.
greyone
« Reply #8 on: October 16, 2010, 08:41:11 PM »
the bearing bridges in my other grey are hand made out of a solid block should not be to hard to make this old grey I have was an ex speedway engine
weddo
HIS, HER's & OUR's
« Reply #9 on: October 16, 2010, 10:10:14 PM »
Thanks guys, have now sourced some bridges
Weddo
Page created in 0.047 seconds with 16 queries.
