August 23, 2025, 03:49:09 PM *
Author Topic: Starter Wiring  (Read 2300 times)
« on: September 06, 2010, 05:03:24 PM »
 Roll Eyes wiring the Pano and I have struck trouble with the Ignition/Starter circuit.
When the SOL terminal on the ignition switch is plugged into the upper terminal on the solenoid I get nothing.
If I plug it into the lower terminal and the key is turned to the ON position the starter motor runs, click it over to START and the starter motor stops  Huh
What have I done wrong?
« Last Edit: September 06, 2010, 09:58:08 PM by stinky » Logged
stapla
« Reply #1 on: September 06, 2010, 08:05:44 PM »
On the switch, do you have your battery feed on BAT ?
If you feed 12V to IGN terminal instead of BAT I think it would give that result.
Peter
« Reply #2 on: September 06, 2010, 10:00:15 PM »
Thanks Peter, what about earthing the switch? The FE/FC wiring diagram looks to have an earth coming off the switch.
« Reply #3 on: September 07, 2010, 10:57:37 AM »
 Embarrassed Dyslexia, I wired the ACC and SOL the wrong way around  Roll Eyes
Page created in 0.024 seconds with 19 queries.
