August 05, 2025, 05:00:11 PM *
Author Topic: Body n Bits  (Read 1525 times)
jasonr70002
« on: August 30, 2010, 03:56:27 PM »
Hey all up for grabs is an FE sedan an FC ute and other bits. The sedan has had all rust repairs finished in the shell except the spare wheel well and needs a good subframe but the FC has a reasonable subframe with rust under the sway bar area. It also needs a wiring loom but also can be taken from the ute. there are 10 or so doors in various states of repair but 2 fronts and one rear are very good and the other rear is an easy repair. The ute still has the grey etc and a speco floor shift in it but the ute is unfortunately beyond repair with extensive rust but has good bits on it like the dash and other bits as well. The sedan has no seats so if using the ute seat you will need to find a rear. There is also a good bootlid and bonnet, windscreen and passenger front guard on the sedan and only needs bonnet catch area etc and steering box and front end. Also in the sale is a HR front end with torana stub axles but no brakes and also needs another lower control arm as the one on it has had the pivot hole in the control arm rounded out and will also be supplied with the rare spares mounting rubber kit for it to the FE still in the box. The car will also come with an EH 3.55 diff so you only need to buy new wheel cylinders to match the disc brakes and also comes with new shackle rubber kit and spring pad kit but needs the two big front bolts with the screwdriver head on them. Also has a good fuel tank in the sedan. There is also a standard bore 149 with the sale and comes with a brand new set of .060 MAHLE pistons with hastings rings to reco the old donk and most engineers will let it go without the need of heaps of modifications in queensland.There is no grill or bumpers or headlights etc for the sedan so still need to be found. There has also been a chassis strengthening bar added on both sides to stiffen her up and only needs final welding. There is also the correct tailshaft to fit aussie 4 speeds etc into FE. There are other bits that I am sure I have missed but they will be thrown in as well you will also need to bring wheels as I only have a couple of spares to roll them up onto a trailer and the ute is about 5 minutes from here. I am chasing around $2000.00 for the lot which is pretty cheap considering the HR front end, EH diff, New rubbers and new pistons along with the new repair panels that are in it. I am doing up an EH wagon so EH guards, bonnet, subframe etc can be considered in a part trade if you like or a good wagon etc.
I am in Kingsthorpe which is just outside toowoomba QLD. 04313766069 or 07 4699 3890 and ask for jason.
Golden Holdens FE-FC
Page created in 0.137 seconds with 16 queries.
