September 07, 2025, 01:00:17 PM *
Author Topic: whats the best exhaust to use  (Read 10111 times)
Jordo
« on: August 18, 2010, 08:02:05 PM »
I am after some advise regarding the best exhaust system to use on my FE,  I have a 202 red motor, manual 5 speed, hurricane headers are fitted, but I am after advise on the rest, what tube diameter to use, muffler type, over or under the diff, single or twin exhaust, I am after a nice sound and better performance.
Craig
« Reply #1 on: August 18, 2010, 08:04:53 PM »
 I run a Single 2 1/2" over the diff with a 16" body sports muffler ......FC427....
jack_fc
SouthWest Coast, Victoria
« Reply #2 on: August 18, 2010, 08:22:03 PM »
and that's about perfect.....   if you want to be a noisy young lout like FC427  Wink
(I'm a respectable senior citizen; I added an 18" 'hotdog' resonator to what he's got, and it's still way over legal decibels in Vic  Cool Grin)
« Reply #3 on: August 18, 2010, 08:45:48 PM »
Jack respectable my butt , and thanks for being so sensitive to the DISABLED  I'm 60% deaf and I thought it was quiet  Roll Eyes Roll Eyes......FC427.....
FCV08
FE FC Club of QLD
« Reply #4 on: August 18, 2010, 10:01:22 PM »
Craig (Jordo)
With my 192, 4speed I ran a single 2inch and split over rear axle into down pipes behind the rear wheels.
Looked good and sounded great as sound bellowed in under car as well.
Just another consideration.
Craig D
jack_fc
« Reply #5 on: August 19, 2010, 09:39:33 AM »
Jordo, if your 202 is relatively stock bar the extractors, you may find 2 1/2" too big. Pipe diameter needs to be matched to each particular motor with regard not only to its capacity but also its extent of modifications. Too large is just as bad as too small... This also seems to apply to mufflers; a stock engine seems to need much smaller length/number of mufflers to achieve a given decibel level compared to a highly modded engine of same capacity (I found that a 2.5" muffler that was VERY loud on my modded 202 sounded fine on my shitty old daily with a near-stock 350 SBC)
Also, I've found that fitting a tailpipe with larger diameter than the rest of the system might look good, but actually seems to sound worse...
(not to mention those people fond of fitting 'jam tins' on the end of their system  Roll Eyes)
All of the above are observations collected over many years of sometimes stupid modifying by a very much 'bush mechanic'; I'm sure there are many others on this forum far better qualified to give you good advice...
cheers, jack
perth_ute
« Reply #6 on: August 19, 2010, 12:11:17 PM »
I have warm 202 with 4 speed. Exhaust recommendations. Firstly no one likes the drone at cruze so don't go 2 1/2 unless 100% race car. I have 2 1/4 (manderal bend if you can afford it) with fiberglass race luky muffer and no drone. get long and thin muffler, fit towards the diff (option to add another muffler at exit if you need it quiet) with xu1 headers or tri extractors with single out the back tucked up close to the body so its not on show with end slight bend towards the road. Its clean, legal, no drone, barks, and works.
jack_fc
« Reply #7 on: August 19, 2010, 03:15:27 PM »
perth_ute probably means something like this-
(personally, I believe exhaust systems are the opposite to kids - they should be heard but not seen... )
« Last Edit: August 19, 2010, 04:48:25 PM by stinky » Logged
« Reply #8 on: August 19, 2010, 03:55:51 PM »
You can't go past the KENRICH JET EXHAUST TIP
Raw 50's POWER  Shocked
Revhead_Fc
just put a chev in it
« Reply #9 on: August 23, 2010, 02:09:47 PM »
Hey Jordo
Don't be soft you don't need an exhaust unnecessary weight more performance without:)
Ben
Page created in 0.049 seconds with 16 queries.
