September 06, 2025, 02:09:20 PM *
Author Topic: exterior door handles  (Read 3226 times)
GMHwagoon
« on: July 30, 2010, 08:00:42 PM »
can someone tell me how do you take apart the handles to replace inner spring thanks
Maco
« Reply #1 on: July 31, 2010, 07:43:17 AM »
Hi,
You will need to remove the 'c' clip with caution at the back of the handle.
Better in Green
GMHwagoon
« Reply #2 on: July 31, 2010, 11:24:56 AM »
thanks can the c clips be replaced if broken
Maco
« Reply #3 on: July 31, 2010, 03:47:19 PM »
I don't think you will break it. Yes you should be able to get them somewhere.
Better in Green
GMHwagoon
« Reply #4 on: July 31, 2010, 05:07:59 PM »
thanks will give it a go
« Reply #5 on: August 01, 2010, 07:41:42 PM »
Try rotating the ring around if possible to get an edge next to the removal slot - it is very easy to break the handle (although you cant see it when installed) if you push to hard.
GMHwagoon
« Reply #6 on: August 03, 2010, 05:44:38 PM »
yes l noticed that the small lug breaks easily not to worry  will try and lube up the c clip first and try and tap it
 thanks
