May 25, 2025, 05:59:51 PM *
Author Topic: rims?  (Read 2142 times)
njf690
heya
« on: July 28, 2010, 11:25:04 AM »
i am having a drama with rims for my conversion using commodore brakes setup all round. what i really want to do is run rims to suit original hubcaps.
tried hq 14' but dosent suit brake setup 290mm rotors from hoppers stoppers.dont really want wb mags rims 15'.
dont want to compromise a good disc setup allround.
« Reply #1 on: July 28, 2010, 01:14:02 PM »
Contact your local wheel repairer for a custom made set, or get some one-offs made at Dragway.
ratbox
« Reply #2 on: July 28, 2010, 02:52:21 PM »
yeah there'll be nothing factory you could put original caps on would have to be something custom made i think even then you'de be lucky to get something
« Reply #3 on: July 28, 2010, 07:42:00 PM »
Im in the same boat want to run 330mm on the front and want a stock look so will need minimum 17 inch rims but there is no way i can do it unless i have a custom set of billet wheels made and the PCD of the commodore pattern will be to large for the FC hub cab so i am back to thinking i will have to run 290mm rotors and  mini moons.
