August 23, 2025, 03:53:47 PM *
Author Topic: Tailshaft to diff connection  (Read 3617 times)
maroon-fc
« on: July 28, 2010, 09:56:55 AM »
G'day guys, this is probably a simple question for most. My tailshaft is attached to the diff by clips. How do they come off?  Tongue
Slightly off topic, what is the correct size bolt for joining the inside front guards to grill? I seem to have a menagerie.
Thanks in advance.....FC Mikey
Wild thing....you make my heart sing,
you make everything groovy,
C'mon c'mon wild thing.
« Reply #1 on: July 28, 2010, 10:05:42 AM »
Mikey,
Those clips must be U bolts, undo the nuts on the backside of the yoke, then slide them out.  The tailshaft should now slip forward and allow removal.
Bob_FC_Ute
« Reply #2 on: July 28, 2010, 01:45:28 PM »
Prior to the use of "U" bolts the tail shaft was held in place by Caps. The caps were held in place by 4 bolts which were removed on the Diff side of the Universal Flange. There were also soft metal plates with tabs, the tabs were tapped up against the bolt heads so that they did not become loose.
Wrap thin wire around the caps so that they do not fall off the universal joints when removing the tail shaft from the vehicle.
Refitting is the reverse of the above, ensure the gearbox is in neutral to allow aligning of the Caps into their correct position Universal Flange.
« Reply #3 on: July 28, 2010, 03:09:30 PM »
Mikey, re the guards, it should be the same ones that hold the guard to the skirts, 7/16 AF head with a screw type thread.
re the tailshaft, as Bob has said, undo the bolts & the clip will come off with them, then just should slide forward & away, if it's an original diff & uni, should have no U bolts, just 4 7/16 head bolts
Maco
« Reply #4 on: July 28, 2010, 03:47:05 PM »
Dave,
You have mail.
Better in Green
maroon-fc
« Reply #5 on: July 29, 2010, 12:25:20 PM »
Thanks guys, it's as you said Bob, hopefully I'll get at it tonight  Roll Eyes
      Cheers FC Mikey
