August 05, 2025, 04:58:02 PM *
Author Topic: metal seat trim  (Read 4614 times)
kiwi FC
« on: June 23, 2010, 10:22:02 AM »
im looking for the metal set trim for the drivers side i already have the passenger side
FX1975
« Reply #1 on: June 23, 2010, 11:59:21 PM »
I have a pair I'm in western sydney PM me if your interested
kiwi FC
« Reply #2 on: June 27, 2010, 10:18:15 AM »
sory i havent worded that very well i mean im after the moulded metal seat surround rather than the plastic ones
« Reply #3 on: June 27, 2010, 11:43:59 PM »
So you are looking for FB/EK seat trims.
kiwi FC
« Reply #4 on: June 30, 2010, 10:49:43 AM »
If thats what they are off when i got the seat the passenger side surround was chucked in I thought they must have been an after market thing . I'm recovering the seat and just thought the metal surrounds would look better if I could find a drivers side surround
TTV6FC
« Reply #5 on: June 30, 2010, 06:08:37 PM »
Where are you located?Is the username a hint?.....I may be able to help with the trims.Jamie.
« Reply #6 on: June 30, 2010, 11:05:43 PM »
Just a tip.
The mounting points for the FE/FC plastic trims are in a different spot to those of the metal FB/EK trims. Be sure to change the mounting points before you get the seat trimmed.
kiwi FC
« Reply #7 on: July 01, 2010, 10:33:17 AM »
thanks for that all good infomation
NIFFTY
« Reply #8 on: July 01, 2010, 05:47:02 PM »
I have a set of FB/EK trims that have been bead blasted,panel beaten,high filled,painted,the s/steel trims have been professionally polished theyare immaculate,I spent $400 on them and did not use them because I didnt know at that time the seat had to be modified,you can have them for $125 if you want to come to the northern beaches
