September 06, 2025, 01:50:12 PM *
Author Topic: Rear springs bolt  (Read 2679 times)
Not Happy Jan
Aussie adventure
« on: May 29, 2010, 02:06:44 PM »
Hi All
Is the nut and bolt that goes through the middle of the leaf springs available from rares???
I got one off and the bolt is pretty well worn and the other the nut is just turning on the bolt Tongue
I picked up a new set of leaf spring inserts the other day but didn't see any bolt Huh
Thanks Nick
You can never have too many!
Port Macquarie NSW
« Reply #1 on: May 29, 2010, 02:38:50 PM »
Yep they are available  its turning as there is like a big screwdriver slot on the inside easiest way if you are replacing is cut the nut off and hit it through with a pin punch.
https://www.americanautos.com.au/secure.html
« Reply #2 on: May 29, 2010, 11:13:47 PM »
Are you talking about the center bolts the ones that hold the spring pack together  Huh if so I get them from my trailer shop .......FC427......
« Reply #3 on: May 30, 2010, 08:43:31 AM »
Yeah now i  have read it again id say thats the one they are after. Undecided
Not Happy Jan
Aussie adventure
« Reply #4 on: June 03, 2010, 03:35:06 PM »
Thanks Boys.
Yes that's right ...I'm after the one that goes through the centre of the leafsprings.
the bolt sits proud of the top of the spring and sits in the hole in the middle of the rubbers for the spring pads and the nut end  fits into the other spring pad??
I'll try my local trailer manufacturer Cool
Nick
Port Macquarie NSW
« Reply #5 on: June 03, 2010, 04:55:58 PM »
It's not uncommon for these to be a little too long on the head & or the thread, just cut them to suit
