August 04, 2025, 08:15:43 PM *
Author Topic: Part Number for FC Mudflaps  (Read 3842 times)
stephen
« on: April 23, 2010, 07:15:17 PM »
Hi .. can anyone help with a GMH part number for the rear mud flaps on a FC  .. I have a chance to get a set with the part number 92020795 and just wondering if they are for an FC .. cannot try them on my car as it is about 80 kilometers away locked up in the spray painters shed ... Regards Stephen
Stewy
sa-club
Jeff Stewart
« Reply #1 on: April 23, 2010, 07:31:40 PM »
Hi Stephen, My parts catalogue lists Mud Deflector Set, rear fender as FE, FC, FB, EK,  7406221
I think the 9 series would be a bit later but still might be similar ?
Someone else might have a later catalogue and a greater insight.
Cheers Jeff.
« Reply #2 on: April 23, 2010, 07:36:13 PM »
Stephen, repros are available, but I don't think they come with the panel that they attach to, although someone I am sure would loan you a pair or send a template to cut your own out of tin
Rear Fender Mudflap Package Part # 7406221
Part numbers commencing with 9 I would think was for late model stuff
Cheers, Gary
stephen
« Reply #3 on: April 23, 2010, 08:02:25 PM »
Thanks for your help Fellows.. I had a feeling they might be off a later model.. DARN .. they are a brand new old stock, original set of flaps with original brackets and fixing screws, all I had to do was swap an old drum pump for them ..  looks like set of repos coming up .. Regards Stephen
fe-ambo
« Reply #4 on: April 23, 2010, 10:08:56 PM »
Sounds like you had a great deal there. Pity they arent FC.
My parts catalogue goes to HR and they still arent listed so must be later again.
Paul
If take a ride in a ambulance you gotta a chance,
if you take a ride in a hearse its gotta be worse.
Check out this website for more photos
http://gallery.oldholden.com/hr-hearse
stephen
« Reply #5 on: April 24, 2010, 09:52:38 AM »
Thanks for that Paul
« Reply #6 on: April 24, 2010, 01:44:08 PM »
G'day Stephen,
The mudflaps you've found are for a VK Commodore.
Regards ACE  Cool
stephen
« Reply #7 on: April 24, 2010, 06:39:35 PM »
Thanks ace .. the bloke that has them is trying to tell me they are off an FC ..  and as I have not seen a pair up close I did not know ,.. they have a piece of yellow tape on them and written in texta is EARLY HOLDEN poss FB FC .. but whoever wrote that is way off the mark ..  anyway looks like  I will be getting a repo set  a bit later when the paintings finished being paid for .. Thanks for your help .. Regards Stephen S
