August 05, 2025, 03:10:16 AM *
Author Topic: Fram Oil Filter Outlet Pipe Hole  (Read 1538 times)
stephen
« on: April 17, 2010, 06:08:42 PM »
Hi .. while my FC is in getting a new coat of paint, thought I would spruce the motor and the things hanging on the side of it up, and when I went to put the Fram oil filter back I noticed that the oil outlet pipe, from the filter back into the block, has a brass fitting that looks a gas bbq fitting, ie a very fine hole Huh is it supposed to have this little fine hole or has some one mixed up the fittings ? .. the only thing I can think of is that it is to build up oil pressure  .. tried to insert photo but not sure how .. Regards Stephens
stephen
« Reply #1 on: April 19, 2010, 09:35:16 AM »
Found an old thread back in Jan 2006 that answers the question and for anyone interested the small hole is supposed to be there and the brass fitting is called a "restrictor" .. Regards stephens
