August 05, 2025, 11:06:51 AM *
Author Topic: What is this???  (Read 5230 times)
jasonr70002
« on: April 13, 2010, 03:21:40 PM »
Found this in one of my stromberg carbies and not too sure what it is. Is it an adjustable main jet as that is where it was screwed into.It has 060 stamped on the top
cheers Jason
Golden Holdens FE-FC
« Reply #1 on: April 13, 2010, 04:34:51 PM »
cheers Jason
Yep!!  Grin
jasonr70002
« Reply #2 on: April 13, 2010, 06:42:23 PM »
Thanks Alex now for question 2 how do I use it and do I need to remove  the jet in the carb. etc
jasonr70002
« Reply #3 on: April 16, 2010, 01:46:29 PM »
C'mon fellas surely someone knows how to use an adjustable main jet  Huh
« Reply #4 on: April 16, 2010, 02:17:26 PM »
G'day Jason, I was waiting to see if someone with more knowledge on these came foreward but it seems not so I'll put in what I know, while I haven't used one of these on a car I have had similar setups on old bikes, when you screw it in (clockwise) it makes the mixture leaner, and when you screw it out it makes it richer, the instructions it originally came with would have had a standard setting e.g. 1 turn or 1&1/2 turns out for example and you tuned it from there, if your plugs are black it's too rich and if there's no colour it is too lean, you're looking for a nice light brown colour, I wouldn't bother with it for a standard setup but if you are running extractors or a bigger cam it would be usefull because it is infinately adjustable.
                                       Pedro
jasonr70002
« Reply #5 on: April 16, 2010, 10:55:48 PM »
Pedro
Thankyou very much for that and I will go and play with it till it runs a nice brown plug.
Cheers for that
Jason
« Reply #6 on: April 17, 2010, 08:34:59 AM »
BUt before you do, Pedro, was that for leaded or unleaded fuel???
FC_fer_me
baby boomers luv FC's
« Reply #7 on: April 17, 2010, 09:18:39 PM »
G/day Jason, I remember using these back in the 70's. As Pedro said you remove the standard main jet and fit the adjustable one then turn it right in and back it off 1 to 2 turns. In those days we used to adjust it until the car would run smoothly out on the highway without hunting and produce an almost white coating on the inside of the exhaust pipe. ( leaded fuel). However with unleaded fuel this won't happen so you'll have to adjust it by trial and error until you get the leanest mixture without hunting.Hope this helps, Cheers, Jack
KFH
« Reply #8 on: April 18, 2010, 08:36:33 AM »
Does anybody on the forum use one of these adjustable jets?  Is the exercise worthwhile in terms of economy/performance.
« Reply #9 on: April 19, 2010, 06:42:22 AM »
Didn't think about that part, the light brown colour would be for leaded fuel, as far as whether it's worth fitting one, it's more for people who like to tinker it's not going to make that much difference on a standard carby, if you want performance fit a two barrel or some twin carbs.
               Pedro
Page created in 0.059 seconds with 17 queries.
