September 08, 2025, 01:46:44 PM *
Author Topic: handbrake cable  (Read 6331 times)
smithy
yeah its purple !
« on: March 20, 2010, 05:10:38 PM »
hi guys, im urgently chasing a photo or photos of a handbrake setup ( original) where it joins the front cable to the rear section. would be super extra bonus if you have a CRS chassis kit.
just need to see how it all mounts and joins....
many thanks
dean
weddo
HIS, HER's & OUR's
billnjudiwedd@gmail.com
« Reply #1 on: March 20, 2010, 10:34:07 PM »
What gearbox are you running, it will make a diference with the gearbox mount. I have a 5 speed behind a red motor on one of ours with chassis kit and had all sorts of trouble getting the right fulcrum point to make the handbrake work correctly. I will post some pics tomorrow when I can.
regards
Weddo
smithy
yeah its purple !
« Reply #2 on: March 21, 2010, 06:32:09 AM »
cheers weddo, same setup as yours.
just not sure if i use the bracket on the CRS gearbox mount or not.
dean
weddo
HIS, HER's & OUR's
« Reply #3 on: March 21, 2010, 04:02:49 PM »
Hope this is clear enough Dean
regards
Weddo
smithy
yeah its purple !
« Reply #4 on: March 21, 2010, 04:19:29 PM »
weddo, spot on mate thank you. picture is perfect and shows me exactly what i needed
just one question the bar which runs through the CRS gearbox mount to connect the front and rear cables, where did this come from or did you make it up.
dean
pedro
« Reply #5 on: March 21, 2010, 04:32:30 PM »
That is very close to the original setup Dean, do you still have yours, maybe you could drill out the spot welds then use the standard bits and knock up a bracket to suit that you could attach to your crs crossmember.
        Pedro
smithy
yeah its purple !
« Reply #6 on: March 21, 2010, 05:21:52 PM »
hey pedro, dont have my original one.
weddos looks sort of beefier than original, got some 2.5 mm flat bar lying around but this may be too thin.
will wait to hear from weddo hopefully if not may have to do a wreckers run during the week.
got the diff guy coming tomorrow to chack on handbrake cable length, but at least now i can sort of mock things up.
time is running fine Undecided
« Reply #7 on: March 21, 2010, 05:39:59 PM »
Dean,
I have a copy of the EK Auto type, the 2.5mm flat bar will be fine to fabricate it from, then make the cables to suit. I am working tomorrow evening, I am home until about 2:00pm. Can lend it to you to copy if you like
smithy
yeah its purple !
« Reply #8 on: March 21, 2010, 06:04:55 PM »
once again, the penguin to the rescue  Grin Grin Grin Wink.
im out at jerraboberra from about 6.30 am till god knows when.
if you are in the area could you drop it off in letterbox and i will make a copy, diff doctor is going to make cable for me during the wek
also would it be possible if i left the dizzy part in the box could you tack it for me ( the location is marked ) and we will work out collection time/location, if not then i will arrange an alternate.
dean
smithy
yeah its purple !
« Reply #9 on: March 21, 2010, 06:22:25 PM »
ha ha ha , just found my flat bar.
i forgot i used it as a brace to strengthen the workbench i built.
how would 5 mm aluminium go down Huh Huh Roll Eyes
may have to make a trip to the wreckers. Undecided
« Reply #10 on: March 21, 2010, 06:23:19 PM »
No problems Dean,
I will drop the handbrake mount off on your front step tomorrow, collect the dizzy, tack it Tuesday AM and drop it back to you
NosFEratu
F4+ =^^=
« Reply #11 on: March 21, 2010, 06:48:13 PM »
And can you get any better service than that?  Grin
NosFEratu
smithy
yeah its purple !
« Reply #12 on: March 21, 2010, 06:49:50 PM »
well yes but it would cost me a packet Grin Grin Grin
ya gotta love the penguin Grin
weddo
HIS, HER's & OUR's
« Reply #13 on: March 21, 2010, 09:40:35 PM »
Dean, I made the 50mm SHS gear box mount myself and originally placed the handbrake cable bracket at the bottom where the small section of 50 x 25 rhs is visible, but it did not work properly. I then welded a 6mm flat plate at the top of the mount and moved the bracket up, but had to run the cable around either side of the 50mm shs which provide a better line for the cable. The front cable was made to suit.
Sound like you have it sorted, well done
regards
Weddo
