September 08, 2025, 09:05:50 AM *
Author Topic: Engine mount  (Read 2763 times)
jasonr70002
« on: March 19, 2010, 09:21:03 PM »
Hey all, Just need info on where to weld on the engine mounts on my HR front end to go into my FE. Pics would be good too.
Cheers Guys
Jason
Golden Holdens FE-FC
« Reply #1 on: March 19, 2010, 09:47:09 PM »
Jason if you still have the original gear box in place best to bolt the red to it and use that for the location don't forget to turn steering lock to lock to check sump clearance to drag link ......FC427.....
jasonr70002
« Reply #2 on: March 20, 2010, 10:50:04 PM »
Unfortunately I don't have a Grey gearbox so I can't use that method. Does anyone have pics or info.
cheers Jason
pedro
« Reply #3 on: March 21, 2010, 04:52:33 PM »
Giddy Jason, sit the engine and gearbox into place carefully checking all the clearances, the steering arms, firewall, floor, starter motor, radiator, tailshaft alignment and length (It's an advantage to fit the tailshaft up temporarily at this stage) etc. then make up the mounts and sit them into place, I'm pretty sure the standard mounts were right at the front of the crossmember and the new ones will be at the rear, let a bit of weight on the mounts so they sit firmly, RECHECK EVERYTHING, then tack mounts into place, remove engine or front end add a couple of triangles of metal on the sides for strength and then fully weld, easy as Wink.
                Pedro
p.s. yes I know I didn't use triangles on mine but i made them long enough so i could weld the rear to the side rail.
Page created in 0.057 seconds with 16 queries.
