September 09, 2025, 04:42:33 AM *
Author Topic: FC Special Sedan  (Read 4751 times)
forefold
« on: January 22, 2010, 11:36:00 AM »
Hi,
       I have a fc special sedan siting in the garage and I need to get rid of it.  I bought it with the intention of getting it on the road as a crusier, but as things change.........baby on the way,  I need to sell it.  I do not know what she is worth so I'm open to offers and advice. It had been sitting for a few years before I bought it so the clutch and brake fluids need to be changed etc.  I had it running the other day and sounds very healthy, only thing is that it may need a new water pump and radiator because it over heated.
Now here are the modifications that has been done, all with receipts :
BODY-
          *  Painted in two pak polac white
          *  Dechromed ( It comes with some spare chrome bits)
          *  Floor pan modifications Weldwell Engineering using 14 Guage steel
          *  Front Sheet metal modified to fit LJ Torana 3 core Radiator
          *  70 Ltr alloy fuel tank
          *  13 x 7 Dragway Indy Wheels
ENGINE-
*202 Red motor with mild head work, cam and roller rockers.  Block has been bored out.  All the usual trick with this engine.
DIFFERENTIAL-
* 3.90 fine spline (32) open centre
* HR holden differential housing
* Shortened LX Torana axles
* Polyurethane bushes
* Rear sway bar
* Standard HR rear brakes
* 9/16th wheel cylinders
GEARBOX-
* Celica steel-case 5 speed
* Custom made tailshaft
Front End-
* LJ Torana solid disc brakes and stub axles
* Master cylinder pbr vh40 brake booster
* EH holden steering column
* 26mm sway bar
* Lowered Pedders springs
As you can see all the modifications are done and all is needed is a little time spent on getting her back up to scratch.  It needs four new tyres and maybe a water pump and Radiator.  I have fitted a new mechanical fuel pump and filter.  It has a dint in the front of the bonnet and the tops of both head lights.
Anyone is welcome to come and inspect,  I live at Springfield Lakes, Queensland 4300.  Ben 0409614957
Here are a few photos...............
forefold
« Reply #1 on: February 08, 2010, 11:09:38 AM »
MORE PICS....
forefold
« Reply #2 on: February 08, 2010, 11:10:59 AM »
PRICE...   $ 4000
GMB-58FC
Stage one complete...
« Reply #3 on: February 08, 2010, 11:25:50 AM »
Any of the dash or seats mate???
ABS Hobart- 6231 5855
PM FOR QUOTE
forefold
« Reply #4 on: February 08, 2010, 02:18:39 PM »
There are no front seats. here is the back seat and dash........
holdek
« Reply #5 on: March 03, 2010, 03:48:36 PM »
Looks like a fairly solid car, would definitely be keen if I was a bit closer. Good luck selling it.
Just out of interest how the hell did it take damage to the headlights like that?  Huh Almost looks like someone went at it with a sledge hammer, same with the bonnet dent.
« Reply #6 on: March 04, 2010, 12:58:14 AM »
My guess would be tapped the back of a truck...
