September 08, 2025, 06:20:39 PM *
Author Topic: hq stubs to lh torana disc  (Read 2630 times)
waynos
patience grasshopper
« on: December 28, 2009, 07:34:13 PM »
i've just put on hq stubs ,disc is rubbing on steering arm bolts will just grind it off
just wondering if anyone else has had this problem?
 cause it seems the left one clears but the right doesnt
i got the stubs from the wreckers and they did have a different part no,but they assured me they were the same
i  knew they wouldn"t fit
has anyone done this without a problem?
FCOV6
« Reply #1 on: January 05, 2010, 06:35:07 PM »
 Although you can fit just about any holden hub/rotor to any stub that uses the same bearings as you have found out the LH rotor has clearance issues and a caliper may be a problem, if you want to keep to 13/14" early holden pattern you will need to go back to HR  or HK/T/G disc stubs or keep your hq stubs and fit HQ-WB or commodore rotors.
« Reply #2 on: January 05, 2010, 06:49:24 PM »
Waynos, I must have missed your original question.
I've never put Torana discs on a HQ stub axle because their is no caliper which will go onto the stub axle that will be correct for the rotor.
