June 09, 2025, 09:45:28 AM *
Author Topic: How can I check the engine Temperature sender  (Read 3467 times)
Eaton_FE
« on: December 13, 2009, 05:18:06 PM »
I am not sure if my engine temperature sender unit is working or not, How can I test it to see if it is. If I short out the wire on it to the body the light works.
The milion dollar question is how do I know if it will come on when the engine it hot.  Huh
Les
rodliz
« Reply #1 on: December 14, 2009, 11:21:05 AM »
A rough way of checking it out is to take it out and hang it in a tin of boiling water and using a multimeter or continuity tester across the terminal and body of the switch--you should have a circuit.
regards Rod
michaels57ute
« Reply #2 on: December 18, 2009, 08:52:07 PM »
I have used this method too, works very well. The resistance should change as the water cools.
CHEERS
Michael
Eaton_FE
« Reply #3 on: December 29, 2009, 11:02:38 PM »
Sounds like it is a good idea, I will give it a go.
Les
Eaton_FE
« Reply #4 on: January 05, 2010, 12:38:29 PM »
1 broken sender unit
Les
