September 07, 2025, 09:30:06 AM *
Author Topic: Petrol Flow  (Read 5251 times)
red_devil
« on: December 11, 2009, 08:28:27 PM »
Hi guys, have had the car parked for five years, so dropped the dirty fuel out of the tank. I disconnected the fuel line at the pump and blew the old fuel down the line back to the tank and out. For some reason we now cant get fuel to flow from the tank even after putting 40 ltr of fuel in, any ideas why no flow. Fitted new fuel pump, had car running with jerry can but not pumping fuel from tank, any ideas.
Red Devil.
« Reply #1 on: December 11, 2009, 08:47:01 PM »
I bet the braided rubber hose you disconnected is now broken inside. It will be now sucking air through the holes rather than petrol from the tank.
Remove the hose and check for leaks.
red_devil
« Reply #2 on: December 12, 2009, 08:28:15 AM »
Thanks Ken will explore and advise.
pedro
« Reply #3 on: December 12, 2009, 11:45:13 AM »
Could have sucked up a bit of crap from the bottom of the tank and blocked the line, if you've got good lungs try disconnecting the hose from the fuel pump and then blowing air into the filler hole to see if any fuel comes through, i bought a car once that ran beautifully around town but would die every few k's in the 100 kph. zone, replaced the carby then the fuel pump. had me stuffed Huh until i found a little beetle carcass stuck in the brass fitting on the tank.
               Pedro
red_devil
« Reply #4 on: December 12, 2009, 01:32:08 PM »
Thanks Pedro working on a process of elimination along that line.
Thanks for posting, it helps.
Red Devil
red_devil
« Reply #5 on: December 19, 2009, 08:43:10 PM »
Guys where is the best place in Sydney to buy the flexible fuel line from the steel fuel line to the petrol pump.
Red_Devil
stapla
« Reply #6 on: December 19, 2009, 11:37:15 PM »
I used pirtek to get a braided fuel hose made up.  I think they needed some of the old fittings.
red_devil
« Reply #7 on: December 20, 2009, 08:42:25 AM »
good call, that would be a premium way to do it once and right.
Red_Devil
« Reply #8 on: December 20, 2009, 03:50:39 PM »
The easiest way if not seeking originality is to use the fitting from a red motor fuel pump and replace the braided line with rubber fuel hose - make sure you use hose clamps each end.
« Reply #9 on: December 20, 2009, 06:15:38 PM »
Red_Devil
The Premium way would be using AN fittings with -6 braided stainless hose it lasts for many many many years .no problems getting a fitting for the fuel pump but would need a male -6  fitting silver soldered on the end of the fuel line ....Earl's ,Russel or Speedflow can supply all that is needed ...........FC427.......
red_devil
« Reply #10 on: December 21, 2009, 06:53:16 AM »
Great guys those are great solutions.
Thanks for the direction, love this forum.
red_devil
« Reply #11 on: December 23, 2009, 05:46:05 PM »
Hi Stapla your Pirtek suggestion got us over the line, $15.00 bolted on started first go. Love this Forum, thank you to all that gave guidance your time and effort is so appreciated.
Merry Christmas to all
Warmest Regards
Red_Devil.
