June 17, 2025, 04:28:20 AM *
Author Topic: ryco r4p filter assembly  (Read 2361 times)
stapla
« on: November 29, 2009, 07:22:32 PM »
Hi All,
Whats the correct method for assembly of a ryco external engine oil filter  ?
Does the spring assembly go the below filter element ?
Maybe from bottom to top - spring, washer, claw bit then filter on top ?
Does the oil restrictor go on the outlet ?
Top side hole to near dissy, bottom center hole to near fuel pump ?
Peter.
« Reply #1 on: November 29, 2009, 09:25:04 PM »
Peter, spring goes at the top to push the filter down.
Restrictor is on the outlet which has a short hose and goes to the hole below the filter. The inlet comes from a tee where the oil light switch is.
