September 06, 2025, 10:01:54 PM *
Author Topic: For sale, carb balancer  (Read 7541 times)
wilburwilde
« on: November 22, 2009, 09:56:33 PM »
Ebay Item #250532199319
And yes i know i used the 'RARE' quote, but they do not appear on there much.
« Last Edit: November 23, 2009, 06:11:09 PM by stinky » Logged
I wish I had lots more money so i could fix the FE and just cruize ALL day!!
« Reply #1 on: November 22, 2009, 10:00:26 PM »
This listing has been removed HuhHuh?..... FC427.......
wilburwilde
« Reply #2 on: November 22, 2009, 10:08:37 PM »
sorry, try again. Forgot only to use the auction number.
Wilburwilde
VAN059
Brisbane, QLD.
« Reply #3 on: November 23, 2009, 11:10:05 AM »
WW,
before bidding, do u know how it works? I have twins to put on my grey and it would be handy to have something to make sure they're set right.
Marc
CraigA
« Reply #4 on: November 23, 2009, 01:24:45 PM »
Its used to measure air flow through the carby.
Invaluable tool for setting mechanical balance with multiple carby setups.
VAN059
Brisbane, QLD.
« Reply #5 on: November 23, 2009, 10:24:04 PM »
Thanks CraigA, I guess what I would really like to know is how its used  Huh. Maybe a simple step by step explanation on what to do, if it's not to long  Smiley
CraigA
« Reply #6 on: November 23, 2009, 11:22:11 PM »
When I tune the Webers on my XU1 I use this method:
#Remove all linkages
#Back off all idle screws until they are off the stops
#Turn them back in until they just make contact, then turn them all exactly 1 turn.
#Start the car, it should idle, if not add half a turn to each screw, repeat until you get a strong idle. Doesn't matter if its a bit fast.
#Now you use the carb balancer to check airflow at each carby. You need to move the idle speed screws until the airflow is EXACTY the same at each carb and so the idle speed is at your desired level. I use a tacho to monitor idle speed.
#Shut the car off and reconnect the linkages to the carbies
#The linkages should not move the throttle from the current position as set above. You can set this pretty close by eye but never as accurately as you can with an air flow meter.
#Start the car adjust the linkages so that the airflow setting is even and idle speed as per previously set. My linkages use a threaded rod at each carb that make adjusting very simple. As a further check I increase the engine speed to about 2000rpm and check that all carbs are flowing the same.
People will have some variations to the above but in general terms that's how you use the air flow meter to balance carbs. There's no question you can do it by eye/ear or by using a bit of hose stuck in your ear but never as good as with the right tool.
Set correctly the carbs will be smooth as throttle position increases. If they are slightly out then you'll get uneveness or fluttering as each carby won't be in perfect unison.
This is the tool I use. Cost about $100.00 off eBay.
CraigA
« Reply #7 on: November 23, 2009, 11:34:17 PM »
Sorry I should have added that the tool in the ePay add is similar to a 'UniSyn' type that is still available new.
Someone like SU Midel in Sydney would have them new but easy to get from overseas websites like Amazon
VAN059
Brisbane, QLD.
« Reply #8 on: November 25, 2009, 12:54:25 AM »
Was sniped right at the end  Angry Dont u just hate that  Roll Eyes, hope it went to a good home (ie Holden)  Cheesy
CraigA
« Reply #9 on: November 25, 2009, 08:42:20 AM »
I wouldn't be worrying too much. You can buy a new one for less than what that sold for.
