July 13, 2025, 06:51:40 PM *
Pages: [1] 2   Go Down
Author Topic: Hobbo's FE Sedan  (Read 13245 times)
« on: October 21, 2009, 09:59:39 PM »
« Reply #1 on: October 21, 2009, 10:14:02 PM »
Looks like a tidy starter.By the way,if you're not planning to use that rear seat which is fall red and obviously from an FC,I am very interested in buying it as mine has a black rubber stain on it which can not be removed.Cheers,Jamie.
« Reply #2 on: October 21, 2009, 10:40:06 PM »
Since when did you use black rubbers Tongue
Hobbo
« Reply #3 on: October 21, 2009, 11:46:36 PM »
 Smiley Thanks for posting our FE on the site, hey Jamie if you've got an FE rear seat I'll trade you ! I've got the matching FC front seat to replace the old FE one, sorry.
« Reply #4 on: October 22, 2009, 10:06:26 AM »
« Reply #5 on: October 22, 2009, 08:22:54 PM »
Bugger...Hey Glenn,I'm trying to make it look bigger.... Grin
brads59
OLD OLDENS=STYLE
« Reply #6 on: October 22, 2009, 08:46:49 PM »
Nice base to start for sure.
Hey im after a front fall red FC bench. Wink
1959 Black Std sedan
« Reply #7 on: October 22, 2009, 10:06:28 PM »
I've got an FE rear bench set if it helps in the "wheeling and dealing", I only need good frames in return.
collecta
« Reply #8 on: October 22, 2009, 10:29:37 PM »
Did you purchase the car from Pat by any chance?
Scott
Hobbo
« Reply #9 on: October 22, 2009, 11:32:03 PM »
Yes I bought it from Pat, I think myself lucky that he let it go. I had my eye on it for awhile and jumped at it when he decided to sell. He bought a few good parts and pulled it apart and put it back together again which makes things a bit easier to work on. But as you guys know it ALOT of WORK and Cash to get it back to GOOD Looking and Driving Condition. I was wrapped to be able to start it and drive it onto the car trailer and rego the next day!
Hobbo
« Reply #10 on: November 09, 2009, 08:19:57 AM »
Hi Dudes, just a quick update on the progress on my FE Sedan. I have fitted the 173 Red and new H/D clutch to the Grey gearbox. EH H/D wide radiator is fitted as is the EH complete diff ass. HR Disc Brake front end is fitted and I have use the complete brake line setup from the EH donor car where f/end came from. Body work is progressing as fast as possible with rear quarters, rear panel, and RHF guard all stripped and repaired. I am trying to get the Fe back on the road asap to allow the painter to get on with his project.... an EH sedan. I will be stripping the doors and boot lid at a later date. Hope to post pix soon, Hobbo.
« Last Edit: November 12, 2009, 01:13:07 PM by stinky » Logged
« Reply #11 on: November 15, 2009, 11:46:12 AM »
HAMFIST
« Reply #12 on: November 15, 2009, 04:27:39 PM »
can i ask what are you using to take the paint of?
Hobbo
« Reply #13 on: November 15, 2009, 05:17:23 PM »
We are using a 7" Grinder with 16, 36 and 80 grit discs? The paint comes off pretty easy but the red oxide and RUST is like diamonds ! The trick is to keep moving to reduce overheating the panel. Needless to say I have to use HI Build undercoat !
HAMFIST
« Reply #14 on: November 15, 2009, 07:01:12 PM »
sounds abit rough on the steel iam using strip discs for the angle grinder takes all paint and rust of and doesnt leave any marks in the steel the discs are made of plastic and can be bought from most places i swear by them and i only have to use regular etch primer to cover it
GM
« Reply #15 on: November 15, 2009, 07:27:17 PM »
Yeah I used a 8" grinder to strip my ute (when I owned it) with 40 grit discs. Worked a treat. Careful when you get to the lead.
            Cheers Glenn
« Reply #16 on: November 15, 2009, 09:34:34 PM »
I have found either works well but sanding discs are a lot more harsh and you have to be very carefull.Strip discs are great but can easily over heat and distort the panel if you are not carefull.Cheers,Jamie.
HAMFIST
« Reply #17 on: November 15, 2009, 11:23:50 PM »
i agree gotta be heaps careful the discs i use heat up the panel quick smart
« Reply #18 on: November 18, 2009, 08:30:05 AM »
jack_fc
SouthWest Coast, Victoria
« Reply #19 on: November 18, 2009, 10:18:06 AM »
Great pics!   Smiley Smiley Smiley
more please
Pages: [1] 2   Go Up
Page created in 0.057 seconds with 18 queries.
